LED turn/tail/brake lights kit from Tore
#151
Here's what I found: Three of the four are up and not touching. One is quite far off the painted surface. I don't have feeler gauges handy right now to measure exactly. Only the left "pad" on the center panel is touching. And, I screwed all 3 adjusters all the way down.
An option would be a piece of rubber on the bottom of each pad. I think I'll do that next time I work on the car.
#153
Just received my rear fog \ brake light harness. Tore now you need to find a front fog light and third brake led light solution!!!
#154
got my kit as well, i'll put it on in the spring...
going off of memory, arent there 4 wires going to the tail lights? the kit includes two wire taps, which two wires are getting tapped into back there?
#157
http://www.bergvillfx.com/files/Rear...sche%20993.pdf
Just thought I'd share a couple of photos with my rear brake lights from Tore...
#158
I'd actually love to make both the current tail lights and the current turn signals into red running lights, BUT with amber flashing for the turn signals (as is currently the case with the amber LEDs from Tore in those locations). Unfortunately, this would require a red/amber switchback setup which doesn't seem to be commercially available.
#159
There are three wires running to each rear lamp. Simply splice into two of the three wires on one of the two rear lamps per Tore's on-line instructions. I will try to post some better pictures when I do the install....
GTGoff, the new center brake lights look great , but are your other brake lights stock? They appear to be dimmer than the new LED's.
#160
Do you have a voltmeter? Stick a pin into the wires while someone steps on the brake to see which wire is power, which ground. Power wire is black/red. Although not clearly so. Ground is brown.
#161
I have to agree that the center panel looks like something that has been over engineered, somebody at Porsche had too much time on its hands...As for the wear areas, installing some kind of clear erosion tape locally seems like a solution.
I have ordered Tore's hid kit last week, obviously before I read this thread.
His brake kit is now out of stock (wonder why) so I will give him to replenish before I spend a few more bucks.
Thanks Tore for the ongoing work you do for the community!
#162
Thank you for your support guys!
My initial batch of rear fog conversion kits are sold out, I made only a small number of kits. I've ordered new hardware from my vendors, and the kits will be ready in 2-3 weeks.
Cheers,
Tore
Cheers,
Tore
#164
Noodle Jr.
Just installed my LED kit but have an issue. When I turn the lights on the drivers side brake light is lit and passenger side is normal. In about 10 seconds it goes back to just the tail light. When I press the brake pedal only the drivers side brake light works. Confirmed with another Rennlister that all wires are routed to the correct sockets.
