Engine Undertray
#46
Yes (I think it was the 964 forum -- but I can't find the thread) and there was almost no difference in recorded temperatures.
There is always the PATENT from 1988...
#47
I leave mine off purely because its easier and quicker to get a trolley jack under the engine casing to jack the car up. I think, as others have said, the trays were fitted by Porsche for reducing noise.
#48
Judging from the scrapes on mine, it is obviously offering some protection, and I consider myself a careful driver over dips and steep driveways... Heater hoses are $150 each, and the flapper box is approx. $100 on Ebay used. Hate to rip all that stuff off in a steep dip incident...
#50
Technical Guru
Originally Posted by Cupcar
FWIW, to add to the data of use, mine was off car when I bought it and will remain off.
Originally Posted by 96PCarrera993mg
Last episode undertray: do a heat gun test on track next Saturday....
#51
I donated mine to Steve Weiner the last time I was up in Portland. He might have mentioned something about using it for testing a "high speed ground effect stabilized stationary air conditioning tower".
I am sure that Rheem is planning a new line of ground effect stabilized AC towers and there will be HUGE market for the old trays.
#52
interesting,the only way to really tell is to instrument the engine and run it, as well as idle in traffic, and most importantly for me, SHUT OFF the engine and let is sit there and cook, and see how the temperature spike.
I see there are threads with guys reading the temps off the engine with and without the cover, but not sure how they do that since the parts you need to read from are covered with the cover --
Funny, I have not seen covers on the 996's or 997's - why is that? Have not been under a 991 yet...
Cheers,
Mike
Cheers,
Mike
#53
As an owner of one, mine still has the cover
#54
This has come up on other threads, and needs to be said again-Porsche engineers aren't perfect when it comes to looking down the road a number of years as to what may bite them in the ***. So, whether it was noise, aero or whatever, there COULD be long term side effects from having the cover in place. The heat soak Mike mentions above is the first thing that came to my mind, and why mine is safely in the attic.
#56
IIRC, the Ferrari 355 was the first car to incorporate ducting on the underside of the car to create a low pressure point under the rear of the car. Quite ingenious if you ask me, creates the downforce without the drag of a wing. It actually is in the shape of a NACA duct.
I do not think the 993 tray is designed to create the same effect.
#57
Am I being unfair, or should anyone who starts a new thread on engine trays should be beaten with one?
#58
