993 Turbo S, Rear Spoiler Parts
Regarding the 993 Turbo S Rear Spoiler-
Does anyone know the part number of the 2 x grommets/inserts on the inside of the Turbo S spoiler that are mounted near where the hinge mounts to the spoiler?
These grommets/inserts (plastic/rubber) are used to cover bolt holes and are about 1inch dia.
Or where I could purchase 2 of these grometts/inserts?
And no I can not find them in the PET catalogue
I ran into the same problem replacing the "pill" shaped caps underside. However I discovered they are the same used elsewhere in the car. (In this case, inside the door jam). Try looking through the rest of the car and you may find the same part elsewhere.
-Then call Sunset Porsche and ask for Andraya.
Hi
Thanks for the advise, if you have the factory Aerokit, does this spoiler have the inserts?
If yes are there part numbers on them?
As most Porsche parts have part numbers on them, even cable ties.
Here's all the part numbers for the Turbo S Wing parts:
1 993 512 333 03 Air Intake Grille - Outer
1 993 512 501 00 Air Intake Grille - Inner
4 999 507 546 02 Fasteners
6 993 512 861 00 Rubber Sleeves
4 900 151 028 02 Washers
3 993 512 633 00 Rubber Spacers
4 900 084 020 02 Hex Nut
4 999 703 146 40 Plastic Plugs
1 993 504 513 00 Rubber Seal
1 993 512 521 00 Spoiler Stop
1 993 512 522 00 Spoiler Stop
4 900 075 355 02 Hex Screws
1 993 512 629 01 Rear Deck Seal
8 999 190 408 30 Rivets
2 993 512 587 00 Protective Strip
1 996 512 213 00 Upper Catch
2 900 075 014 02 Hex Screws
And:
AFAIK all the parts are the same as the regular wing as the PET page seems to indicate. I have all these parts NIB but want to sell them as a package deal with the S wing I have for sell.
And:
Hi
Thank you very much for this information, this forum is great, Porsche have not been able to help todate.
Just for my own peace of mind can you confirm if part 9 (999 703 146 40) is the same as on the turbo S spoiler, that is the 2 x inserts near where the hinge mounts?
Thanks,
Thanks........................
Thanks,
PM sent
Apologies for resurrecting an old thread - does anyone know the part number for the rubber parts in the picture?
Unfortunately they're not in PET as there are subtle differences between the Turbo and Turbo S spoiler.
It's not no. 15 in the picture below - already ordered them and no joy.
I have noticed that the plastic cap from the door seems to fit perfectly over the gap in the spoiler.
Position 6 in the picture, part no. 999 703 345 40.
@DiegoR: maybe you can try for yourself as well and see if it fits.
