The official PORSCHE 993 OBD II test drive
#61
I can't even get the cold start code to reset. Even with the Equus reader I've started the cold car (sat overnight) 3 times to idle at least 5 minutes, no dice. Probably why the others won't set as that one must be 1st if I recall.
#62
Flat-6,
I had the readiness codes issue last year when the battery was disconnected for some service work. I posted some tips on the drive cycle that worked for me on a thread titled readiness codes (I think):
Here's what I did on this drive cycle:
1. I let the car idle before driving for about 5-6 minutes with the heat on, after reading through a readiness code document I found that I had in my Docs_TSB folder. I kept the heat on low throughout the drive cycle.
2. I drove the low speed part of the drive cycle for about 15 minutes, keeping it < 2000rpm and < 30mph. I did have some stop signs, stop lights, etc. during that period.
3. I drove the high(er) speed part of the drive cycle for about 30-40 minutes, keeping it < 3000rpm and < 60mph. Depending on traffic speed I was either in 4th or 5th gear for most of the trip.
At the end of the drive cycle I ended up at a red light, had a look at my tester, and saw the good news! Now I can get my car inspected tomorrow.
Good luck to you. It took me at least 6 attempts to get the codes set so I could pass inspection.
Regards,
David
Regards,
David
#63
#64
"I can't even get the cold start code to reset."
None of the readiness codes/monitors will show as SET until all the
monitors have successfully been completed (SET). If one of the
tests fails during a drive cycle, none will show up on an OBDII
scanner.
Check here for more 993 OBDII readiness tests:
www.systemsc.com/codes.htm
scanner.
#65
OBD Reset Success - fianlly
Success...! Finally after at least 6 drive cycles I was able to reset my OBD. Thanks everyone for your guidance and input. I've been crystal clear all along on the steps but for whatever reason (and after several hundred frustrating miles) they just wouldn't trip. I can only assume that's partially because of my location in a central to San Diego area where the low speed cycles are really tough to complete. Regardless, I will say the investment in the reader was totally worth it as it takes the guess work out completely. Loren was also correct - none show complete until they all do and that only happens after all tests complete properly.
Off to SMOG...
Off to SMOG...
#66
Off to SMOG...
Off to SMOG...
Congratulations! I am about to help a family friend get her deceased husband's '96 993 smogged (it failed on recent attempt due to codes)...I have read ad nauseam about the processes for clearing the codes--and now feel prepared to give it a try. Being in San Diego concerns me a bit on how to find space to drive slow--and for long periods of time! Where did you pick up your Innova? Cost? And--to clarify--did you disconnect reader between cycles? Thanks!
#67
Jordan--
Jordan
#68
oh....and no I did not disconnect it but it didn't much matter having it plugged in during the test. As Loren pointed out in the previous posts all flags remain unset until they are complete their test cycle successfully. Mine all turned from flashing to solid (ready) with a green light while at idle after drive cycle 6 at which point I knew I could shut down safely as the cycle(s) were finally complete.
#69
scanner.
scanner.
#71
I bought the Innova Equus 3100 from a local Wal Mart all in for around $100. It's a little cheaper online but not much < $10 The Wal Mart site also shows which locations have units in stock. But...since you are in San Diego and given that I now won't be needing mine for two years you are welcome to borrow it. Just let me know I'd be happy to meet up anytime. Besides it's also great to connect with another Rennlister and drool over someone else's 993.
Jordan
Jordan
Thanks for your kind generosity! About to send PM...
#72
Just a quick note to say I've used the BMW routine every year since when I got it in '93 and have never had to run it more than once each time. Maybe I'm just lucky.
#73
Jordan
Jordan
Wouldn't surprise me if most of them worked this way.
#74
"3 set fairly quickly (as a group) and the last 5 set as a group during the final idle stage."
Right, those three are the Continuous Monitors which always SET (unless
a real engine problem) immediately. The other 5, which are the problematic
ones everyone has issues with, only SET after completion of ALL drive
cycles (trips).
"Finally after at least 6 drive cycles"
That's only because ALL the required tests didn't complete in a full drive cycle (trip)
and the partial trip was fully RESET when the engine was turned off or stalled.
cycles (trips).
#75
After having read these helpful posts in-depth, I have one final question:
Do the drive cycles have to be contiguous? If I complete one full cycle on a Thursday, and drive around normally on Friday, then do my 2nd full cycle Sat morning, would that work? Or, only under condition I still not exceed the 3,000RPM on Friday's driving? Thanks for input...
