993 Forum 1995-1998
Tip Final Drive Fluid Change **Correction**
Old 12-29-2006, 06:22 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Yes, the fill port is placed at this height for a reason, to set oil level.
Old 01-01-2007, 02:28 PM
pedsurg
pedsurg's Avatar
Dudley: Very nice pics. When you say the washers were replaced do you mean putting back on the original washers or new washers?
Thanks again.
Jack
Old 01-01-2007, 02:33 PM
Greg Fishman
Greg Fishman's Avatar
A easy way to get all the oil out of the Mobil container is to soak the oil in some hot water. It flows much better after that.
Old 01-01-2007, 02:56 PM
Dudley
Dudley's Avatar
Thanks again.
Jack
As a rule, I replace the sealing washers. That being said, I am not sure replacing them after each fluid change is critical on low/no pressure applications. I just feel better replacing them.
Old 01-01-2007, 03:01 PM
Dudley
Dudley's Avatar
Sounds like a winner. I used my Motive Bleeder to pump the fluid in. It worked but I made a mess doing it.
Old 04-29-2016, 02:38 PM
Device2
Device2's Avatar
Dudley, where do you get the sealing washers I've got a 00 Tip 996 with the ZF Auto Trans and the seal on the refill/fill screw looks like its a small Teflon or hard plastic type. This is the information I was able to find from the ZF parts catalog.
ZF P/N: 0636 308 025 Screw Plug M18x1.5
But no actual place to procure it from.
Quick Reply: Tip Final Drive Fluid Change **Correction**
