Convertible Top Problem - Solved!!
#61
"Does anyone know if the control unit for an '87 Cab is the same as this one for the 993?"
It is not the same. There are rebuilt units. Do a Google search ("Cab Top Control Unit").
"can anyone please clarify how to get to this chip?"
What chip?
What chip?
#66
#67
"How to get to the control unit/chip/module whatever you want to call it discussed in this thread."
As I said, do a Google search for "Cab Top Control Unit". Rebuilt units are readily available at about
$300 in all three versions; 911, 964, 993.
#68
you have me confused with another person.. thanks though.
#69
I have a 87 911 Cab, my Roof Controller went. I checked for Cold Solder Joints.. none. I have looked high and low to either have this rebuilt or buy a rebuilt or new. Sent it out to BBA to repair, they diagnosed it, charge me and said "can't". Now I'm looking for a rebuilt or new and can't find one ANYWHERE! I am told it is not interchangable with the 993. What do I do, where do I go? It's Fall in New England and I gotta fix my Baby! Any help would be greatly appreciated! Thanks Folks!!! Joe
#72
Who needs an electric top?
When I had a BMW 328 convertible.... rather than pay $1200 for a new controller, I converted it to manual operation using the parts from the european model. I threw away ten pounds of motors, wiring loom, switches and other junk. Suggest you look into whether this can be done. I bought a 993 coupe because I didn't want the problems you are now having.
#74
"I converted it to manual operation using the parts from the european model. I threw away ten pounds of motors, wiring loom, switches and other junk."
Great for the resale value!
You can also use the Porsche part number (993 618 313 00) when doing a Google search
to find sources for the cab top ECU.
#75
It is no advantage to have an unreliable and overly complex system to avoid a simple manual operation. The buyer of my 328 agreed with me. The fewer electric motors on my car the happier I am. Loren, I wonder if you would also like Porsche to replace the cable operated gas flap with a control unit and motor.... maybe they already did this. One more reason not to buy a newer model.
