Wheel paint issue
Wheel paint issue
So turns out my car doesn't have black wheels? Not sure how it happened, but now I need to find someone to paint them for me.
Does porsche paint the wheels or do they powdercoat them?
What are everyone's thoughts on the 2?
I ordered the platinum wheels and will probably paint them down the road. I think the stock GT3 wheels will look incredible in satin black instead of glossy black. My neighbor just did the wheels on his Q7 in satin black and they look great. If the dealer is responsible for the mixup have him get them painted.
Flat black, smooth with a slightly rubbery feel. I think they have glossifiers now which can make it shiny as well, and paints for different colors. Needs to be redone when you change tires as I found on my BMW that the PLASTIDIP wears at the rim tip where the tools are used to pry off the tire. Plus side for me is my 3 year old forged rims still look brand new.
re: Painted Factory Wheels.
The wheel vendor ('just-in-time' & 'just-in-sequence') for Porsche first paints the wheels and then clear coats them (several times). There is no 'powder coating' involved. There is still an ongoing debate in the 'aftermarket' world if 'powder coating' (which I love in other parts of a restored chassis) might negatively impact a cast and/or forged factory OEM wheels due to the high temperatures involved in the powder coating process. So caveat lector.
Saludos,
Eduardo
Carmel
Saludos,
Eduardo
Carmel
Please refer to your build sheet and see if you paid for painted wheels and Porsche missed it. If you paid then Porsche will get you a new set of wheels.You can always paint them later. Give it chance 1st and see if you get to like the STD color.
Good luck either way.
I would not powder coat.
Too much risk (and unknowns) with respect to the structural integrity of the wheel in that procedure.
It can be done safely, but you have to ensure the time/temp cycle is kept low and short enough so as to not affect the heat-treatment of the forgings. The key is to get cure temps down to an acceptable level. It's tricky, especially if you have an aftermarket tuner working on OEM specs.
Just my 0.02 of course.
I have a different concern. Based on some aging powder coat I have observed on other structures it seems that there is some potential for powder coat to hide the start of a crack in a wheel. Paint doesn't have the substance that powder coat has and therefore show the underlying defect more readily.
There are nondestructive methods to test for cracking, however not affordable for the average DIY'er.
Ryan
