Reduced engine performance problem
Didn't want to freak people out but...
This popped up several times so far. Lift works fine. They couldn't really find any issues and the thought for now is that this message is a "software issue".
Lift system been around for few years. This one is probably a glitch that will get fixed. The reduced performance one is a interesting one.
Saeed said he could not start the car. Not sure about Sam's car.
I am just speculating but doubt bad fuel is the cause. strange that two new owners are reporting same issue within couple weeks of delivery and they both used bad fuel
The 997.2 RS had a compression ratio of 12.2:1 which is very high for a street motor that runs on pump gas by default.
As if this wasn't crazy enough, the 997.3 had it raised again to 12.6:1. Andreas Preunninger himself said, “We played with ratios as high as 13.0:1. However, we encountered some detonation at this level, so we settled on 12.6:1"
With the 991's DFI and a few other tricks, the compression ratio is 12.9:1 (!). Anyone who has a bit of engine building knowledge knows this is insanely high for pump gas.
Throw in the 9,000 RPM redline and a splash of cheap fuel and we got a recipe for disaster.
ECU's these days are very advanced and I'm sure the knock sensor(s) in the 9A1 has very high resolution but that just means she's going to go to limp mode really easily which I suppose is better than throwing a connecting rod out of the block!
Mine drives perfectly fine, until 7,000 RPM. It'll behave like you hit the rev limiter.
I hope it was "a splash of cheap fuel" or a bit of water that did mine.
I'm going to have some fun and speculate here.
I don't have my gt3 yet but I'll take a stab at it since I see regularly on a different brand. (BMW x6m with and without dinan)
1. Acceleration without warm up. Happens very often. You can pretty much count on 50% if you launch from dead stop.
2. Bad fuel.
3. Bad fuel pump triggers this. ( replaced twice)
Solution: none, flashed software three times, two pumps and a lot of free coffe.
Turn off ignition, restart and good to go.
I could be totally wrong so don't shot me.
2. Bad fuel.
2. Bad fuel.
2. Bad fuel.
Received 1,268 Likes
I am really worried now :-(
It could be either one; I'd take easy with the revving until it gets looked at.
Well, DFI allows for almost diesel-like compression. For example, Mazda now has 14:1 on a rather simple and cheap DFI engines (http://www.mazda.com/mazdaspirit/sky...kyactiv-g.html). Also, at high RPM engines are less susceptible to detonation. Not saying that there is not a problem with something - obviously there is - but it's not because this compression is fundamentally difficult to achieve.
It'd be nice if E85 was supported. I reckon this problem wouldn't occur.
In Saeed's case he could not start his car while it was safe for your car to drive. You would think with same error message they both behave the same unless his message is different. Unfortunately his message is blank. DARN IT
Saeed, please repost your error message. Make sure the picture extension is .jpg
Wonder how long it will take them to diagnose this new engine? wonder if they will need to escalate?
The fun part of getting one of the first cars I guess. Hoping it is resolved soon so that you can have her back.
2. Bad fuel.
2. Bad fuel.
I believe it may be #1 as above from Dude.
Remember Sport Auto in Germany had the exact same issue with their demo car. The one they did the 7.30 Ring lap in. They put it on the dyno and it flashed a message and would only run up to 7000 rpm. Porsche reputedly sent a rep over with a panel and re-flashed the ECU. They never said exactly what the issue was but we speculated on here it may be due to the way the car was run on the dyno, apparently many modem sports cars find there ECUs trigger a fault not understanding how the car is being used. This may be something propriety to the new Siemens ECU used in teh GT3 for the first time.
In regard to the fault code you are running here 00004, this may simply be the system that shorts the fault but not particularly indicative of the issue at large. If it is Id be guessing low octane fuel or perhaps the engine needed to warm through more before use....
Just a few ideas, but dont panic yet. Its an embarrassing thing to happen at a track day I must admit so I understand how you feel, but I think this may (hopefully) be a simply software issue thats already reported with the car,. Afterall I know at least four others already using tehcar at the track in Europe that have had no issue. In Europe you can get 98 RON everyhwere and 100RON in many countries. Thats 93 MON and 94 MON for USA. So the gas in Europe is still better than USA. 12.9 compression is getting close to full race car standards just a few years back (13.0-14.0) in a road car and with those race cars only hi octane race fuel was used....
Everyone calm down. Sam, stop biting your nails!
