991 GT3, GT3RS, GT2RS and 911R 2012-2019
Pic request: Carrara White Metallic GT3s
Old 12-12-2014, 01:25 AM
Mech33
Mech33's Avatar
Default Pic request: Carrara White Metallic GT3s
I'm looking for a little help in a last minute color decision between White and Carrara White Metallic. Could all you lucky folks with your Carrara White Metallic GT3s please share pics of your cars? Thanks!
Old 12-12-2014, 01:43 AM
orthojoe
orthojoe's Avatar
I was initially white, then saw a CWM cayman GTS and switched to CWM. Then I had the CWM cayman GTS in my garage and drove it for a week. I realized that after seeing the car in person for a while, it looks pretty much plain white and not worth the extra money, so I switched back. Plain white will be a brighter white, whereas CWM will have a slight gray tinge to it when in the shade.
Old 12-12-2014, 01:45 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,482 Likes on 2,269 Posts
very subtle difference unless side by side.
post the pic of my car next to CWM GTS on ur driveway
Old 12-12-2014, 01:57 AM
Mech33
Mech33's Avatar
Sounds similar to my color choice history! Here are my current thoughts on CWM:
1) CWM is less "yellow" than plain white. CWM has a slight "cold" color temperature to it. The plastic bumpers painted CWM also seem to match the body color better than plain white (the plain white bumpers never seem to match well and definitely look yellowish).
2) On the downside, CWM is "sparkly". In bright sunlight, point light sources that reflect off the car look purplish and sparkly, which doesn't look very "racecar" compared to the plain white. I assume this metallic flake will also make the paint harder to match for any respray work, though a good paint shop should be able to handle it.
My car is currently in the system as plain white. But given the better bumper matching with CWM, and the generally less "yellow" appearance, I'm tempted to switch if I can just get over the glittery appearance...
Old 12-12-2014, 02:02 AM
LAGinz
LAGinz's Avatar
Theyare both are good choices. I think Orthojoe pretty much nailed the differences I see live.
Old 12-12-2014, 02:04 AM
Zucc
Zucc's Avatar
Here you go:
Old 12-12-2014, 02:20 AM
Mech33
Mech33's Avatar
Thanks, the car looks great! It's hard for me to tell that it's CWM in those pics. If I had to guess, I would have bet that that was regular white.
Old 12-12-2014, 02:22 AM
FORENN
FORENN's Avatar
Originally Posted by Zucc
Here you go:
Good lord that looks good with the silver wheels.
Old 12-12-2014, 02:42 AM
orthojoe
orthojoe's Avatar
This one?
Old 12-12-2014, 02:46 AM
orthojoe
orthojoe's Avatar
When you look at it in this light, the CWM looks better, IMO. However, it is my understanding that the new carrara white is a brighter white than the 987/997 white.
Old 12-12-2014, 03:16 AM
LAGinz
LAGinz's Avatar
Before ordering, I looked at this a lot, both live and in pics. I believe the current regular white is just called "white" and it is not nearly as yellowish as the previous Carrera (non-metallic) white. It looks pretty neutral to me, and indeed before CWM came along, people on this forum sometimes referred to it as an "appliance" white color. To me CWM is a still colder white with gray undertones, especially in the shade. To me, in bright light they look pretty similar, with CWM having a very slightly colder tinge. In the shadows the regular white, for me, has a lot more pop, as the CWM goes slightly dull because of its grey undertones. On the other hand CWM, as with most metallics, can look more interesting in certain other light conditions such as dusk, or under flood lights or fluorescent lights. Both are very good colors for the GT3. YMMV
Old 12-12-2014, 05:28 AM
Jimmy-D
Jimmy-D's Avatar
Received 1,389 Likes on 720 Posts
In the end; I do like standard white better for the GT3. Just more "pop" and racer-like. If I were to get a Cayman GTS or a Turbo - may go metallic
Old 12-12-2014, 06:22 AM
hfm
hfm's Avatar
https://rennlist.com/forums/991-gt3/...-120314-a.html
Lousy photos but CWM.
Old 12-12-2014, 07:12 AM
Macca
Macca's Avatar
100% agree with this and 991 GT3 "white" is very different from Carrara White.
Old 12-12-2014, 08:58 AM
shapiroeric
shapiroeric's Avatar
Same as others said...hard to tell the difference unless side by side...
Quick Reply: Pic request: Carrara White Metallic GT3s
