Spyder/Cayman R Discussions about the 987 Spyder/Cayman R (2011-2012)
987.2 Spyder 3.8L X51 Conversion
Old 04-20-2014, 07:14 PM
Hoopumpers
Hoopumpers's Avatar
Default 987.2 Spyder 3.8L X51 Conversion
I have a 2012 Boxster Spyder with 9k miles on it.
6MT, sport buckets, PSE
I've owned a number of high performance cars, many of which are/were far more expensive or exotic. The Spyder is the first car that has ever made me say: "I am keeping this thing forever". I feel it is the most perfectly balanced, rewarding, involving and fun road car I've ever driven. It's also stunning to look at and quite rare from a production standpoint. Steering, transmission, weight, suspension are nearly flawless. Other than a few very minor modifications to camber, a 3rd radiator and 6pt harnesses, it is (ok...was) completely stock.
I've always said the car has only 2 faults:
1. It has the word "Boxster" written on it
2. It could use another 100bhp
The first issue was largely fixed by removing the rear badging
The second issue is more involved. I've done a fair amount of research on options to eek more power out of the 3.4L stock engine. I've also driven an aftermarket TPC Turbo setup on a similar car. From my point of view, neither were going to get me where I wanted to be.
The fact is, we all know that Porsche won't erode 911 sales by making a better mid-engined car (unless it's a super/hyper car). So, the boxsters and caymans are neutered.
That's where Dwain, Roland and the rest of the Vision Motorsports team came to the rescue. They were looking for 3.4L engines to tear apart for testing and were offering a reasonable deal on a brand new 3.8L motor with X51 powerkit.
- Engine will be mounted about an inch lower for clearance
- Custom intake will be fabricated
- Coding will mash up 997 and 987 settings
- Aasco lightweight flywheel
- Sport clutch and pressure plate
- And a few other simple mods should yield a target power output of 430bhp
Here are a few shots of the car before work began, and some progress along the way
Al Allen (12-28-2022)
Old 04-20-2014, 07:29 PM
Hoopumpers
Hoopumpers's Avatar
The transaxle has been bolted to the new engine, flywheel installed and all mounted back in the car. Final assembly, intake and tune are all that remain. Hoping to pick it up later this week.
Old 04-20-2014, 07:40 PM
skxf430
skxf430's Avatar
What an awesome build and nice to see this done in Socal. Please keep us posted on your progress and thoughts on the car.
Old 04-20-2014, 07:54 PM
hf1
hf1's Avatar
Received 1,640 Likes on 1,122 Posts
^ +1
Old 04-20-2014, 08:21 PM
il pirata
il pirata's Avatar
Nice.
Will you/did you weigh the difference between engines or the car when finished?
Old 04-20-2014, 08:47 PM
Hoopumpers
Hoopumpers's Avatar
Good question. Supposedly the weight difference is negligible, but I'll try and get more scientific info than that
Old 04-20-2014, 09:00 PM
Alan Smithee
Alan Smithee's Avatar
Glad a Rennlister took advantage of their offer, and that it is going into a Spyder. Looking forward to the result! If my Spyder had another 100hp, I wouldn't have sold it.
Brave to give up your warranty - or have to fight Porsche for it. And, more importantly, are you not concerned about eventual smog inspection?
Old 04-20-2014, 09:08 PM
ChrisF
ChrisF's Avatar
Received 1,047 Likes on 383 Posts
Subscribed
Old 04-20-2014, 09:17 PM
Z356
Z356's Avatar
Default Limited Slip Differential...
Rob: Best of luck with this project. What did you decide to do about the stock factory Limited Slip Differential? We have had some interesting conversations at this forum with Alex Ross of Sharkwerks and Matt Monson of Guard Transmission about the subject:
https://rennlist.com/forums/987-981-...s-today-3.html
And also at Planet 9:
http://www.planet-9.com/987-cayman-b...dissected.html
Let's us know which way you went as far as LSD!
http://www.guardtransmissionllc.com/...differentials/
Saludos,
Eduardo
Carmel
Old 04-20-2014, 09:31 PM
Hoopumpers
Hoopumpers's Avatar
Alan, this should pass smog with flying colors. It's 100% stock from Porsche. It just happens to be the engine designed for a Carrera S with Powerkit
Eduardo, it's a good point. There are a variety of other upgrades that may make sense someday: Guard LSD, brake upgrade, more rubber. Will get some seat time and see how it behaves.
Old 04-20-2014, 09:38 PM
hf1
hf1's Avatar
Is this a DFI 3.8?
Old 04-20-2014, 09:50 PM
Hoopumpers
Hoopumpers's Avatar
^ Yes DFI 3.8
Old 04-20-2014, 09:59 PM
Alan Smithee
Hate to be the voice of reason, but I am pretty sure the replacement engine must be the same year as the car or newer, and that a visit to a BAR referee will be required, even if it does pass the sniff test...
Old 04-20-2014, 10:09 PM
orthojoe
orthojoe's Avatar
That may be true, but how would the smog tester know? I agree that he will be fine with smog testing.
Hoopumpers:
Old 04-20-2014, 10:59 PM
Alan Smithee
I do not pretend to be an expert on this - my cars are all either too new or too old to require inspections - but I expect all will be told when the plug goes into the OBD port.
Quick Reply: 987.2 Spyder 3.8L X51 Conversion
