BBi Autosport Porsche 981 Cayman S Weekend Track Build
Basic Sponsor
Attachment 1344394
This Porsche 981 Cayman S will be a total sleeper in the canyons. Underneath the stock interior, we will be installing our BBi Autosport track suspension and safety package with goodies from COBB Tuning, JRZ Suspension Engineering, Borla Performance Industries, and Cobra Racing. Here are some pictures of the build progress that we would like to share. Stay tuned for updates!!!
Upgrades and Services Performed:
Interior/Safety:
Engine/Transmission:
Suspension Upgrades
Brakes:
Wheels/Tires:
Exterior:
- Jerry@BBiAutosport.com
Interior/Safety:
- BBi Autosport GT4 Roll Bar Satin Black
- BBi Autosport Seat Base & Slider Kit
- Cobra Suzuka Pro Racing Seat
- Schroth Racing GT3 Harness
- Borla Exhaust
- IPD Competition Intake Plenum
- GT3 82mm Throttle Body
- Cobb AP
- Torco SR5 GDL Fully Synthetic Oil
Suspension Upgrades
- JRZ RS Touring Coilovers
- BBi Adjustable Thrust Arms Front Pair
- BBi Adjustable Thrust Arm Bushings Front Pair
- Tarett Engineering Adjustable Sway Bar End Link Front
- BBi Rear Toe Adjustable Toe
- Tarett Engineering Adjustable Sway Bar End Link Rear
Brakes:
- New Brake Rotors
- Endless MX72 Pads
- Brembo HTC64 Brake Fluid
Wheels/Tires:
- New Michelin Pilot Super Sport Tires
Exterior:
- Xpel Ultimate Paint Protection Film Full Nose
- ClearPlex Invisible Windshield Protection Film
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Basic Sponsor
To extract the more power and improve response, we installed the IPD and Cobb Power Package,
IPD Competition Intake Plenum & GT3 82mm Throttle Body Installation
To improve airflow, we used the IPD Porsche 981 Competition Plenum to replace the restrictive factory plastic unit.
BBi 981 Stage 2 Power Package with IPD Competition Plenum & Cobb Accessport V3 ECU Upgrade Package
981 IPD 82mm Competition Plenum
Custom IPD silicone Hose Designed to Perfectly fit The alarger 82mm Throttle Body
Diversion Splitter and Dimpled Interior
The new 981 Plenums also benefits from the internal dimpling effect that have been implemented on all Plenums moving foward. This internal dimpling allows us to control the boundary layer and maximize airflow. Just like a dimpled golf ball travels farther than a smooth golf ball. Controlled turbulent air creates less friction and "tumbles" over a given area more efficiently.
IPD 981 IPD 82mm Competition Plenums Features:
• Increases horsepower, torque, and boost responsibly optimizing air flow efficiency
• Utilizes diversion splitter and dimpled interior surface eliminate turbulence and increase air flow
• High quality cast aluminum construction
• Direct fit OEM replacement
• Larger 82mm competition plenum version available
• Made in USA
Side by Side Comparison Between the Factory and IPD 981 IPD 82mm Competition Plenums:
82mm vs 74mm Throttle Bodies
Cobb Tuning Porsche Cayman GT4 Accessport V3
Features
- Cobb AP V3
• Made in USA
Features
- Simple Installation: Everything is included for the simple installation you can do in your driveway! Intuitive on-screen instructions identify your exact vehicle, saves stock vehicle data, and displays available OTS maps.
- Change Maps: Store up to 100 maps from our OTS map database or from your favorite COBB tuner and quickly switch between them for any need.
- Vehicle Upgrade Support: As you continue to modify your car, Accessport maps can be used to optimize performance upgrades. Changing the map can be done in less than 1 minute in your driveway.
- In Car Mount: The Accessport can be mounted in vehicle to allow you to monitor the performance data.
- Data Logging: Record multiple data channels simultaneously for in-depth evaluation of engine performance. Stores up to 1 hour of continuous data.
- Gauges: Use your Accessport as a gauge to monitor boost or any other live information, directly from the ECU.
- Trouble Codes: Read engine trouble codes to diagnose issues. Clear them when resolved. Prevent expensive trips to the dealership.
- Full Uninstall: Using the Uninstall option will completely remove our programming from the car’s ECU. It is then able to be re-installed after a dealer visit or on another vehicle.
Basic Sponsor
To improve handling, we installed our Stage 3 BBi Street Cup Suspension package along with JRZ RS Touring Coilovers & Tarrett Engineering's Adjustable Sway Bar End Links. Our upgraded components provided the additional adjustment ranges to help maintain proper suspension geometry that not be achieved with the factory arms.
Suspension Upgrades
Front Suspension
Rear Suspension
BBi Autosport Rear Adjustable Toe
- Provides additional rear toe adjustment
- OEM link is non-adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
- Helps maintain proper rear end suspension geometry
- Each kit includes pair of 2 Links
BBi Autosport Front Thrust Arm Kit
- Connects the Lower Control Arm to the subframe
- Provides precision caster adjustability
- Spacers included for setting stock or anti-squat and anti-dive configurations
- Each Kit Includes Pair of 2 Links
- Fits both front and rear axles
BBi Autosport Front Adjustable Thrust Arm Bushing Kit
- Provides two eccentric mounting points
- Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
- A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
- Compatible with all stock Porsche 996 and 997 lower control arms (including Porsche Motorsport Cup arms)
- Sold as a set of 2 or a Complete set of 4
Tarrett Front and Rear Adjustable Sway Bar End Links
- Simple bolt-in replacement for the factory drop links
- Left & right hand threaded rod-ends allow for simple length adjustment to eliminate swaybar preload
- Correctly sized, precision, Teflon-lined rod-ends for smooth and quiet operation, long life, and high reliability. No wear and rattling problems, like those seen with other designs, due to undersized or low-quality rod ends
- Eliminates the factory compliant plastic drop link bushings that deflect under loading and quickly wear out
- High misalignment, stainless steel spacers allow for superior bind free operation and corrosion resistance
- Precisely connects the stock or adjustable swaybar to the front strut assembly for improved feedback and swaybar response
- Overall length is adjustable to accommodate either stock or adjustable swaybar requirements
Basic Sponsor
Worn Brake Rotors and Pads
For improved braking performance, we replaced the worn pads and rotors with upgraded components. We chose the Brembo Racing HTC 64T High-temperature brake fluid because it provides a very high dry boiling point and the Endless brake pads Tare the ultimate, dual-purpose street/light track that combines an aggressive initial bite and good heat resistance all while keeping dust and noise to a minimum.
Brakes:
Brembo HTC Brake Fluid
To ensure optimum stopping performance, brake fluid should be replaced every two years because it can absorb moisture over time and also lowers the boiling temperature, reduce braking effectiveness.
BENEFITS:
New brakes installed
Brakes:
- New Brake Rotors
- Endless MX72 Pads
BENEFITS:
- Brembo HTC 64T can handle high temperatures without loss of pedal feel (independently proven low compressibility).
- Has been specifically formulated to provide the highest performance and consistency under all racing conditions.
- Has an extremely high dry boiling point
- The higher viscosity of this fluid delivers a “stiffer” pedal and provides stable performance under extreme temperatures (critical in professional motorsports)
- Boiling Point Dry: 335 C / 635 F
Impressive work! I'm always interested in upgrades that provide meaningful results, and without a doubt the suspension and safety upgrades appear to be reasonable. It would be informative, if possible, to post some actual real-world dyno results (before and after the upgrades) to quantify the "increased horsepower and torque" claims. I believe there is ample evidence with regard to the benefits in the 3.8L engines (spyder and GT4), but less so with regard to the 3.4L engines.
Reports from individuals on another forum (planet9) seem to indicate that at best there is a 10 HP gain (at the high end) but only after a customized tune on a dyno. Seems like a lot of work and expense for marginal usable HP gains, and potential warranty issues, especially in light of the fact that Porsche is able to squeeze out 15 extra HP on the 3.4L GTS versions with what appears to be only tuning adjustments (I believe the GTS has the same intake and throttle bodies as the S versions, but please correct me if I am wrong on that). I'm definitely not questioning the quality of your work, which is obviously high end, only that I believe some real data would be helpful to those interested in at least the engine performance upgrades.
Basic Sponsor
After the suspension and power upgrades are in, we installed our Safety Package which includes Bolt-in Roll Bar, Sub-Strap Mount, and Shroth 6 point harnesses to properly secure the driver and provide additional protection.
BBi Autosport GT4 Safety Package:
Key Features
Cobra Racing Suzuka Pro-Fit
Features:
BBi Seat Base & Slider Kit Porsche 996/997/991/987/981 Seat
Features
Seats Mounted on our BBi Seat Base & Slider Kit
- BBi Autosport GT4 Roll Bar Satin Black Finish
- BBi Autosport Seat Base and Slider Kit
- Cobra Racing SUZUKA PRO-FIT
- Schroth Profi GT3 6 Point Harness
Key Features
- Chrome moly steel tubing utilized for excellent strength to weight ratio
- Modular construction to allow access to engine for servicing without removing entire roll bar
- Shoulder harness mounting crossbar positioned at appropriate height as per Schroth's instructions
- TIG welded and utilizes "X" braces on rear section for superior strength and rigidity
- Mounts to frame structure and rear strut tower to provide strongest mounting points and maximum protection
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
- Designed to work with stock or any aftermarket seats on the market
- Minimal affect on seat travel to accommodate taller drivers
- Can be used with stock seat-belts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even curve
- Finished in satin black powder coat. Other colors available
- Bolt-in installation requires no drilling and minimal carpet trimming
Features:
- Side mounted only
- Available in standard or GT (+30mm width)
- Unique PRO-FIT custom padding system
- Full 6 Point harness facility
- Hans compatible
- High sided lateral support
- Breathable Spacer fabric
- Optional Outlast cooling system
- Supplied with high tensile bolts pre-installed
- Integrated wear patches
Features
- Precision CNC laser cut and bent from one piece of 1/8” 3mm carbon steel (base & side mounts)
- Multi way adjustability
- High strength sliders, mounts to base with 4 bolts per slider
- Integrated 5 and 6 point sub belt mounting locations
- Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
- No modifications to vehicle or any seat mount components are required for installation
- Uniquely designed for Porsche vehicles for the best possible fitment
- Mounts to factory bolt locations with precise factory fitment
- Fits all major FIA/SFI approved seats up to 17”
- 14-3/4”¬(375mm) to 17-1/2”(445mm) width adjustments (standard side mounts)
- 16”¬(375mm) to 18-3/4”(445mm) width adjustments (optional wide side mounts)
Basic Sponsor
Basic Sponsor
2014 Porsche Cayman S StreetCup Track Project finished with a new set of HRE Performance Wheels R101 Lightweight wheels (16 lbs front, 19.4 lbs rear) wrapped with a set of Michelin Motorsport Pilot Sport Cup 2 tires.
- jerry@bbiautosport.com
