968 Forum 1992-1995
In for a Penny, In for a Pound
Old 02-06-2017, 10:27 PM
  #61
Jay Wellwood
Jay Wellwood's Avatar
Question Have you checked your fuel level sender?
Well have you?
Not sure if this applies across the board, but here's an observation. Some times the leg bone is connected to the neck bone.
Case in point, Passenger door is nearly stripped down, save for the door wiring harness. The connectors have to feed from the passenger side footwell where they plug in, through a small hole near the door opening. Only problem is that there is a wiring harness already in the same opening, limiting the free opening even further still. Ok...remove the offending wiring harness...it traces back to the trunk area where two wires go to each wheel well to serve what appears to be the ABS wiring. Those connectors are sandwiched between the forward edge of the gas tank and what makes up the rear seat backrest area...so the fuel tank has to come out first, then the aft wiring harness, then the door wiring harness, then the door can finally be removed.
Of course, when I got Wilma, there was no instrument cluster, so no telling how much fuel might be left in the tank...pick up 2 5 gallon tanks and that turned out to be just about right. I figure about 8 gallons of vintage '12 unleaded was left to be drained.
FWIW - removing the roll up windows is a challenge without potentially damaging the runners that are attached tot he aft end of the window that ride up/down in the rear window track. PO who was disassembling Wilma didn't take to heart the tried and true method of look hard and tug gently.
Old 02-06-2017, 10:41 PM
  #62
FLT951
FLT951's Avatar
I'm gonna get a cushy lounge chair, a beer n pizza delivery service and come watch you. Any thing else I should bring besides my blankie?
Old 02-06-2017, 10:50 PM
  #63
Jay Wellwood
Beer & Pizza ought to do it... I've got plenty of wrenches, sockets, hammers, etc etc etc.
Old 02-06-2017, 11:06 PM
  #64
FLT951
FLT951's Avatar
I'm good with a hammer, not so much with the others. Where would you like me to start?
Old 02-10-2017, 10:19 PM
  #65
Jay Wellwood
Default Anyone ever wire a bypass switch...
Anyone ever install a bypass switch for this? It's a common mod made by those in the 928 crowd.
Finally got the passenger door off this week and nearly gave myself a hernia removing the anti-vibration ballast in the passenger side trunk well. That thing must be nothing short of 50+ pounds tucked down inside and under the edge of the trunk opening.
Old 02-11-2017, 02:13 PM
  #66
jsheiry
jsheiry's Avatar
Jay,
When I drained the tank on jungle rot she had almost 10 gallons of orange stinky 23 year old fuel. PITA Scrap metal place would not take car without draining the tank. Two five gallon buckets with some orange homer HD lids sealed up that haz mat in my side yard. Not sure that crap would even burn if I put a torch on it. I saw that big mass in the rear passenger fenderwell/trunk area and thought it was some sort of impact protection for the gas tank??
Old 02-11-2017, 03:42 PM
  #67
touareg
touareg's Avatar
What is that switch for?
Interesting on the weight, I forgot about that, the 944S2 Cab I had, had that also.
Old 02-11-2017, 04:18 PM
  #68
FLT951
FLT951's Avatar
I have had a dozen of those weird engineering genius or logic defying plugs in S2's and 968's and maybe even the original 83 944. Plenty of interesting guesswork explanations why it is there. Anybody know the real reason?
If it was ballast why not add a page to the Owner's Manual asking people to put their bag of parking $25 in that hole?
Old 02-11-2017, 06:32 PM
  #69
Jay Wellwood
It's the kickdown switch for the tiptronic. A popular mod in the 928 crowd (where a majority of those cars are Automatics) is to install a bypass switch. It offers a 'sportier' performance in the 928 4 speed automatics.
Old 02-11-2017, 06:36 PM
  #70
Jay Wellwood
Originally Posted by jsheiry
Jay,
Wow John. The gas here doesn't appear to be contaminated - still, it's probably better for the lawnmower/weedeater/blower.
The counterweight is for the Cabs - not sure how Porsche determined it's weight. Placement must be based on the assumption that the car would likely have only a driver. Supposed to minimize cowl shaking/car vibration...YMMV
Old 02-12-2017, 01:39 PM
  #71
Jay Wellwood
Default The things you find...
Buried under the Passenger Seat, connected to the electrical harness for the Tiptronic you'll discover one of these - a Lateral Accelerator Sensor. Not completely certain, but I'd venture a guess it has something to do with shutting down any demand signal to the Tiptronic in the event of unstable moment (rollover perhaps?). Quite pricey new from the Stealerships.
Old 02-12-2017, 02:12 PM
  #72
Boeing 717
Registered User
Boeing 717's Avatar
I think it's for the torque vectoring system.
Old 02-12-2017, 09:13 PM
  #73
Jay Wellwood
Today was supposed to be Passenger Compartment Wiring Harness Removal day. Somehow I managed to get distracted by removing the last of the gas tank fill components (which notably requires the removal of the passenger side trim piece to easily access the gas filler neck gasket mounting screws and flange).
Photo for effect....this week I'm in hopes of doing the wiring harness victory dance.
Old 02-13-2017, 10:13 AM
  #74
touareg
touareg's Avatar
In that case, are you looking to leave it on all the time? Not sure how having that switch on with the pedal not depressed in WOT would work?
Maybe take a switch for the center console?
Grab an extra rear wiper switch and stencil SPORT on it ?
http://www.ebay.com/itm/PORSCHE-968-...3D291911348374
Old 02-13-2017, 10:15 AM
  #75
touareg
touareg's Avatar
Wow, I must admit that is thoroughly disgusting in there, but fun I am sure none the less!
Seems all the glue is gone?
Quick Reply: In for a Penny, In for a Pound
