968 Forum 1992-1995
Deciding on Color Choice for 968 Repaint
Old 04-04-2015, 11:46 PM
  #76
968gene
968gene's Avatar
Originally Posted by touareg
Looking forward to seeing your interior. What type of material did you decide to go with for the dash covering?
I opted for a high quality vinyl instead of leather. There wasn't much difference in cost but because the sun can be brutal on leather, I went with the installer's recommendation (the vinyl).
Old 04-06-2015, 01:23 PM
  #77
Jay Wellwood
Jay Wellwood's Avatar
Based on the photos on their website, the quality of the work is top notch.
Old 04-07-2015, 11:29 AM
  #78
jm964cab
jm964cab's Avatar
You have put in an incredible amount of work. Great choices and very awesome looking!
Old 04-19-2015, 03:23 PM
  #79
968gene
968gene's Avatar
Default Heat Control
Added some Zero Clearance material from Koolmat, their stuff is great.
Replaced the exhaust side and tunnel as well as adding to the turbos side.
Old 04-19-2015, 05:15 PM
  #80
Jay Wellwood
Looks great Gene.
Plans to shield the Master Brake Cylinder area?
Old 04-19-2015, 08:55 PM
  #81
968gene
968gene's Avatar
Originally Posted by Jay Wellwood
Looks great Gene.
Using the 951 shields and thinking about adding a turbo cover from Koolmat as well.
HVAC, wipers, and harness in...
Old 04-19-2015, 09:37 PM
  #82
touareg
touareg's Avatar
My question is how do people keep track of where to put what! When I pull someting apart, I am usually pretty good at a few notes, and memory since it goes back together right away. But if I did a restoration, no hope for me
What tricks have others done to make sure things are done as well as they can, wire routing, screw sizes, etc.
Old 04-19-2015, 10:46 PM
  #83
968gene
968gene's Avatar
Well, most wire connections only go together one way, the Porsche PET lists just about every fastener by size, type, and placement, then there are pictures I have of the disassembly...and a parts car for reference...otherwise I'm lost too!
Old 05-17-2015, 08:07 PM
  #84
968gene
968gene's Avatar
Before and after.
968 Mancave wall art.
Old 05-17-2015, 10:35 PM
  #85
ForceReconTrojan
ForceReconTrojan's Avatar
awesome, just awesome. been following this.....wow.
Old 06-30-2015, 09:43 PM
  #86
968gene
968gene's Avatar
Default fuel tank filter
Decided to clean the fuel tank and replace the tank filter...there was a bit of sediment in the tank and the gasket was toast! BTW, I have an extra gasket if anyone is interested....
Old 07-01-2015, 12:28 AM
  #87
touareg
touareg's Avatar
I want the hood above
Old 07-01-2015, 07:38 PM
  #88
968gene
968gene's Avatar
Default Additional heat shield
Added this today...made by a local NASCAR supplier
Old 07-01-2015, 09:04 PM
  #89
Jay Wellwood
Hmmmpppffff....and just how long do you think that paint will last Mister?
Old 07-03-2015, 11:41 PM
  #90
sm
sm's Avatar
Can the tank filter be replaced while the tank is in the car? If yes please share details. Thanks
Quick Reply: Deciding on Color Choice for 968 Repaint
