964 Forum 1989-1994
964 rear end travel?
Old 03-20-2017, 08:15 PM
txhokie4life
txhokie4life's Avatar
Default 964 rear end travel?
I have a new to me ~55K mile 92 C2 Cab.
When putting it through its paces on road I've noticed what feels like
some side to side travel, I'd almost call it sway in the rear end. Especially felt in moderate speeds when I turn in. To me it feels like the rear suspension travels sideways, then takes a set. It sort of feels like oversteer, except the tires are planted. Only moves enough for me to think -- did that just happen?
I've never driven an early stock 911, so I really don't know whether this is normal or not.
My wife's stock 993 feels solid. A former 996 I had felt like the 993 from a rear end perspective.
The car is completely stock -- and if that's normal -- I'm fine with it -- I'll learn to deal with the character, however, if its a sign of something has tired -- then I'd like to get it replaced.
I'm not interested in upgrading -- or firming up what is otherwise stock -- I have plenty of track toys to waste my money and kidneys on :-)
thanks,
Mike
Old 03-20-2017, 09:26 PM
cscrogham
cscrogham's Avatar
Not normal-start with an alignment ck and the easy stuff.
Old 03-20-2017, 11:58 PM
-nick
-nick's Avatar
Still on the original engine mounts?
Old 03-21-2017, 12:25 AM
-Danno-
-Danno-'s Avatar
+1
Old 03-21-2017, 01:18 AM
Vandit
Vandit's Avatar
The car's rear suspension is engineered to have active geometry called the Weissach-effect, however after 25 years and all those miles, I guess the rubber bushes don't keep control of the geometry like they used to.
https://rennlist.com/forums/964-foru...ch-effect.html
https://rennlist.com/forums/964-foru...ce-needed.html
Old 03-21-2017, 01:23 AM
Spyerx
Spyerx's Avatar
Received 1,730 Likes on 1,058 Posts
My very clean non-worn 964 was floppy. Replacing every joint with a monoball fixed that!!! :-)
Check the spring plate and swing arm bushings. Also check the rear shocks are good. And the engine mounts.
Old 03-21-2017, 09:54 AM
prschmn
prschmn's Avatar
With that mileage I'm not sure that bushings should be a problem but shocks and or alignment
might be-I'd check rear toe first---being a frugal kind of guy
Old 03-21-2017, 10:16 AM
kylejohnston1
kylejohnston1's Avatar
I would check the engine mounts first. They are notorious for failure. I bought 993 engine mounts from Pelican and they worked well. Avoid buying mounts on ebay.
Search this forum for engine mounts and you will get plenty of results. Good luck!
Old 03-21-2017, 12:24 PM
911Jetta
911Jetta's Avatar
Originally Posted by txhokie4life
...When putting it through its paces on road I've noticed what feels like some side to side travel, I'd almost call it sway in the rear end. Especially felt in moderate speeds when I turn in. To me it feels like the rear suspension travels sideways, then takes a set. It sort of feels like oversteer, except the tires are planted. Only moves enough for me to think -- did that just happen?...
Like others have said, I'm sure at least part of the sway is coming from your motor mounts.
It's easy to check for sagging motor mounts:
Old 03-21-2017, 02:26 PM
peter_jansen
peter_jansen's Avatar
Mine did the same. Motor mounts. Changed to wevo and reinforced the carrier.
Old 03-21-2017, 02:37 PM
txhokie4life
Thanks folks -- I'll check the engine mounts (and other ideas) the next time I head out to my storage garage!
Mike
Quick Reply: 964 rear end travel?
