Crazy or there's a mint green coupe in there
#76
Nice work, I can't wait to see the end result. I'll be repainting as well.
I noticed you are using a long Dura-Block to wetsand.
Are you using sticky back paper? If so, what brand are you using & what grit are you using?
I ask because some sticky backs don't hold up to wet sanding.
#78
I cut the seals with a razor knife front was a pain glued in black colored adhesive rear window was a breeze glue looks light color and dried up between the glass and seal between the seal and car body same as front black rubbery stuff
#82
Someone from the Mint Green Team PLEASE send John one of those "Mint" tee shirts like in post #35!! The man is ON A MISSION!! ("On a mission from God" .. Blue Brothers).
Hey John, have you seen that other thread asking about the door plugs underneath each door?
https://rennlist.com/forums/964-foru...r-edition.html
They are talking about the serial #'s stamped in the rear section of each door metal. Have you checked yours (just for giggles)??
Keep up the great progress John. We all CAN'T WAIT to see it back in all it's Minty Green Jean Glory!!
=Steve
=Steve
#83
You can see inside the circle con the top picture the rusty area I found when I removed the passenger side front fender makes me sad in some ways but dam happy it is a small area should be an easy fix
#85
Back on Talia
I got the flu earlier this year and got lazy. Felling better now So back to working on Talia with the help of my grandson we pulled the left side front fender and also the spoiler. I found rust in the same spot on the left side as I did on the right side still not bad and should be easily fixed
#88
Glad to see an update, John.
#89
Slow and steady wins the race said the tortoise to the hare. Looking good.
#90
