964 Cab wet under rear carpet
Hi all,
I've noticed water under the rear carpets of my 93 Cab. From reading various posts it seems to be linked to blocked drainage holes around the hood (not the ones in the front under the windscreen). Does anyone know where to find them and how to unblock?
Thanks!
Fred.
Thanks!
Fred.
IHI KING!
Its pretty easy to clear the drains. But you should also look for other water intrusion areas such as window seals.
https://rennlist.com/forums/964-foru...ater-vent.html
https://rennlist.com/forums/964-foru...-a-cabrio.html
IHI KING!
In the cabs and targas, there are no rear drains. The HVAC has two drain tubes, both accessible from underneath the car, next to the fuel pump cover. Remember water will collect behind the front seats in the foot well. Its the low point of the floor.
Note: The coupes with sunroofs, have rear drains. The tubes exit the car at the engine cover, near the hinges.
