964 Forum 1989-1994
My 964 Escapades
Old 02-10-2016, 02:03 AM
  #46
kokolyia
kokolyia's Avatar
Originally Posted by canuck964
kokolyia:
Firstly congrats on the car. Looks fantastic and you will definitely love the sports seats.
Second I noticed that your interior is missing the lower dash just like mine. Except mine is a ROW car so I believe that is the norm for ROW models. However, I always thought that all NA cars had the lower dash.
Your car -
My car -
Example with lower dash -
Noticed the upper glove box in both our cars. It was replaced with lower glove box to make way for the passenger air bag.
Maybe it is because of the model year? Maybe the Canadian cars are closer to ROW than the US cars?
I personally like it better without the lower dash.
Thank you! I prefer it without the lower dash as well. Here is something I found on sttuttcars.com
Old 02-13-2016, 10:22 PM
  #47
kokolyia
kokolyia's Avatar
I finally cured the horrible tire noise from the circa 2004 tires and am very happy with the conti extremecontact dw's. I also decided to put 5mm spacers on the rears.
Is that fine or is the lack of front spacers and issue?
Old 03-22-2016, 07:39 PM
  #48
kokolyia
kokolyia's Avatar
Some speaker "fun" (Read PITA)
https://rennlist.com/forums/964-foru...-mounting.html
Old 03-22-2016, 08:01 PM
  #49
kokolyia
kokolyia's Avatar
Rennlist is one of the greatest things ever created. I spent the weekend changing my oil (it was black as you can see from the pictures), replacing the hood struts, getting the license plate lights to work ( I replaced them with LEDs and repaired the wires), replaced my blown 5.25 inch speakers with 6.5 inch coaxials and some tweeters from a fellow rennlister, and fixed the sticking interior passenger door handle. If only I was always this productive with my time!
I will attempt to round up all the links I used to help me for those who are looking to do the same things.
  #50
kokolyia
kokolyia's Avatar
Oil change
I am a new fan of Brad Penn 20w-50. The engine ran smoother the minute I changed it. Concerning that picture with the white bench, if the bolt on the bottom of the engine is stuck, I recommend jacking the left side, putting a 15mm wrench
on the bolt and wedging it against a hard surface, and then lowering the car on the jack. The weight of the car will loosen the bolt
http://www.964uk.com/Documents/How%2...%20a%20964.pdf
Old 03-22-2016, 08:45 PM
  #51
kokolyia
kokolyia's Avatar
Found the whole reason my license plate lights weren't working was two cuts in the wire deep in the bumper ( I went fishing with some needle nose pliers) and the badly corroded light housings. A simple and direct replacement was an LED version I found on Fleabay. Now they're almost too bright!
Old 03-28-2016, 05:21 PM
  #52
davidwilson11
davidwilson11's Avatar
Hi there, what bulbs did you get for the rs rear section?
Old 03-29-2016, 03:30 AM
  #53
g60pops
g60pops's Avatar
Looks like a US rear section and not a RS one.
Old 03-30-2016, 05:04 PM
  #54
kokolyia
kokolyia's Avatar
I used these. It is a US section actually but the bulbs will work great regardless.
http://www.ebay.com/ulk/itm/262288373148
Size:  363.9 KBName:  photo810.jpg
Old 03-30-2016, 05:15 PM
  #55
Netbug
Netbug's Avatar
I purchased license plate LED lights and took them off. They are so bright that they are brighter than the reverse lights. Just my 2cents
Old 03-30-2016, 06:14 PM
  #56
kokolyia
kokolyia's Avatar
I thought about taking them off but I decided that this will make drivers behind me more aware at night and will draw attention better to the infamously small brake lights on a 964
Old 03-30-2016, 06:58 PM
  #57
Mr.Alex
Mr.Alex's Avatar
This is one of the reasons I left my LED plate lights in, they are super bright which is not a bad thing on such a small car at night.
Old 05-05-2016, 02:16 AM
  #58
kreeshp
kreeshp's Avatar
Thanks to this thread, I too bought a pair of the LED license plate bulbs discussed here and am very happy with them, having just installed them tonight.
Their obnoxious brightness I consider a safety feature - more visibility can't hurt when trying to avoid being rear-ended by the text-messaging, distracted hordes. The anemic bulbs they replaced are ridiculously dim by comparison.
Quick Reply: My 964 Escapades
