Headlight adjustment plastic socket
When changing bulbs I noticed that my headlight bowl was not complete fixed. OK the long screw used for adjusting the light horizontally the plastic socket is not longer connecting with the "ball" on the bowl trim.
I searched for a replacement component but can't find it, alternative I will have to glue it shut of use clamps to keep it in place.
Help wanted
Help wanted
The cups on my headlights are also quite worn, but they are luckily still working sufficiently. I searched for a solution a while ago and could not find anything. However I do think that this is a part that can be 3D printed.
I had the same problem recently. I just replaced the plastic piece with a metal nut , and a different screw of the same length. There should also be a spring to help secure the fixture.
