964 Forum 1989-1994
964 A/C retrofit in Non-A/C Car
Old 06-16-2015, 07:21 AM
justinliu
justinliu's Avatar
Default 964 A/C retrofit in Non-A/C Car
I have a 1989 C2 that didn't come with factory A/C. What parts do I need to retrofit A/C into the car? Is it a better idea to just go with something aftermarket?
Anyone selling a complete a/c system from their 964?
Old 06-16-2015, 09:40 AM
justin-in-athens
justin-in-athens's Avatar
These are the people and components you will need. Give them a call. http://griffiths.com/porsche/air-conditioning/964-993/
Old 06-16-2015, 01:03 PM
Vandit
Vandit's Avatar
Interesting thread... So does the engine compartment not have an AC compressor bracket ala Carrera RS?
Is the HVAC unit behind the gas tank totally void of an evaporator?
Does the car's harness not have the evaporator temperature probe?
I'd probably start with taking inventory of what the car does and doesn't have, then make a big list, then create some "want to buy" threads and contact some dismantlers and start collecting a bunch of parts.
Old 06-19-2015, 09:41 AM
MA7008O
MA7008O's Avatar
I did it a few years ago, and it was no hard. Bought a damaged car with A/C and got all the parts from it (much simpler and cheap).
Engine braket is different, and the HVAC has the space for the evaporator.
The electrical harness is the same, but I used an external switch to turn the system on, since I missed the A/C control unit and it was very expensive.
Old 06-28-2015, 11:08 PM
justinliu
justinliu's Avatar
Is the engine bracket different? From what I can see the engine bracket is the same as there is a mounting bracket to mount the compressor like my other 964.
Old 07-01-2015, 10:11 AM
MA7008O
MA7008O's Avatar
Non A/C car usually come with a bracket that does not has the compressor support, so you need to change that.
Old 07-04-2015, 04:59 PM
onceover
onceover's Avatar
I'm of no help here but i noticed you said 89 C2. Either its a C4 or a 1990/newer
Quick Reply: 964 A/C retrofit in Non-A/C Car
