I searched, can't find DIY on E-Brake pad change procedure
I have searched and searched... I can't seem to find a write-up anywhere on how to remove and reinstall the rear emergency brake shoes.
Any idea on where to find this?
Thanks for any help!!
Cheers,
Bryan
Cheers,
Bryan
This is about as far as I needed to go in order to remove the rear trailing arms from the car. It's a start...
https://rennlist.com/forums/964-foru...ub-solved.html
There's a great thread in the 964 DIY section. Sorry on Iphone, or would link it for you.
HowTo: Checking and Adjusting Parking Brake
06-03-2005 08:49 AM by JasonAndreas
THX
Guys, much appreciated. I figured it out and all in and loving their new home. Will adjust once I get the rotors back on.
The old pads were just that.. old. 1/2 of the pad on the passenger side fell off the bracket and the other one was all cracked so needed to be replaced. This way I'll have a good e-brake and also will last a long time. All hardware looked in very good shape.
Thanks for all the quick help!! I couldn't find the DIY before.
Regards,
Bryan
Regards,
Bryan
