964 Forum 1989-1994
How do you bleed the clutch
Old 02-09-2015, 12:43 AM
fishing
fishing's Avatar
Default How do you bleed the clutch
I did a quick search and couldn't find a link. I am going to flush the brake fluid and it is recommended to bleed the clutch at the same time. Is there a link or, if not, how do you bleed the clutch? Thanks, Scott
Old 02-09-2015, 01:05 AM
greg1990964
greg1990964's Avatar
Same as brakes. Need a power bleeder. Nipple on the slave cyl on top of transmission. Get your arm up there and feel around. Should be a few threads about this. It's easy. You may want to buy a new rubber line as they don't last forever and let in small amounts of air.
Old 02-09-2015, 01:12 AM
fishing
fishing's Avatar
Great. Thanks. I have the power bleeder. It sounds like it may be difficult to loosen the nut.
Old 02-09-2015, 01:48 AM
Vandit
Vandit's Avatar
Make sure the reservoir is topped up, it's really easy to get air in the clutch circuit. Make sure you clamp off the overflow softline near the reservoir otherwise you'll never build PSI on your power bleeder. The bleed nipple on the slave cylinder is 7mm.
Old 02-09-2015, 04:09 AM
jevvy964
jevvy964's Avatar
Good tips! The space is limited which means you cant easily go from fully closed to open with one sweep of a standard spanner before it hits stuff and you cant easily slide it off the nipple if you are using a drain tube of some sort. I thinned the end of my spanner so I could easily slip it off the nut area of the nipple and rotate it before sliding it back onto the nut to nip it tight/loosen it further, you could probably chop the spanner in half to increase the amount it can rotate instead if you would prefer.
Plan B if you are having no luck in the space is to remove the slave from the gearbox and bleed it where you have more space since its connected to the car with a rubber hose but beware it can be a right fight to refit it sometimes.
Good luck!
Old 02-09-2015, 10:01 AM
Goughary
Goughary's Avatar
It's not hard to do, as has been said. I found however that I needed to run a lot of fluid through the Slave to get it running clean and clear, so you might want to use your motive bleeder wet rather than dry. And in that case, be sure to protect your frunk in the event the cap pops. But wet bleeding is very helpful so you don't introduce air to the system...
Old 02-09-2015, 10:10 AM
dsan
dsan's Avatar
^^^ This x2 ^^^
I'll second that, I found it much easier to wet bleed it and not introducing air into the system.
Old 02-09-2015, 10:28 AM
9six4
9six4's Avatar
I've found that it can take a few tries to get all of the air out. I've had issues in the past where I think that I've done it correctly but the clutch pedal goes to the floor. Top up the fluid and bleed it again until the pedal comes back.
You need to get the wrench on by feel as you can't see it when you have your arm in there.
Also don't forget to remove the 7mm wrench, ask me how I know!
Old 02-09-2015, 11:44 AM
KaiB
KaiB's Avatar
My setup is bit different of course, given the Tilton clutch and annular bearing, but...
I've long wondered why not run a bleed line from the slave up through and into the engine bay. I ran mine all the way to the top of the engine (adjacent to the fan shroud and clamped there) and simply bleed standing up from there. It is so simple I bleed the clutch each brake bleed; for me, every ten hours.
Wouldn't this work?
Old 02-09-2015, 12:06 PM
mike9186
mike9186's Avatar
Bleeding the slave cylinder with also give you a good indication of whether you need a new slave cylinder or not. When I first did mine, no fluid came out at all.
Access is a real pain but not really hard. It is one of those area that you can look at or get your hands on but not both at the same time. I like to use a closed end wrench on the bleed nipple because you can let it hang while bleeding and then it is much easier to get it closed when done.
Old 02-09-2015, 01:06 PM
Hem
Hem's Avatar
I did mine a few months ago using the following thread as my guide...and as a bleeding newbie, it worked out very well the first time.
https://rennlist.com/forums/964-foru...procedure.html
The only thing I had to do on the brake caliper bleeder nipples was to use a socket to get them loose..flare wrenches and box ends didn't have enough bite.
Old 02-10-2015, 07:30 AM
wachen
wachen's Avatar
I just want to reiterate what others have said...top up your reservoir.
I recently did mine and only filled the fluid to the MAX line. I did not realize just how high the pickup for the clutch system is in the reservoir. I found out the hard way and introduced air into the system.
So, I would fill the fluid to the brim (when using power bleeder, dry method).
Old 02-10-2015, 11:30 AM
Goughary
Goughary's Avatar
I always do this with the car on jack stands, but I heard once that if you jack the rear of the car and take the wheel off to bleed the clutch slave, you can't get all the air out since the angle of the slave is wrong. Rear of the slave is higher than the bleeder... Since we are discussing tips and tricks, is there any truth to that?
Old 02-10-2015, 11:56 AM
JB 911
JB 911's Avatar
Good tips in this thread and +1 on using the power bleeder wet. If you do it dry and open the slave for too many seconds you will get air. Ask me how I know. I will do it wet next time AND top up first. Next time I might also break it up into 2 or three sessions of bleeding with a pause to depress clutch a dozen or so times to agitate the new fluid around the dirty surfaces before continuing.
Old 02-10-2015, 12:57 PM
C4inLA
C4inLA's Avatar
Worth reading Workshop manuals on subject matter. If return line pinched off and power bleeder attached, you need to know when and when not it is okay to pump pedals during various steps system wide.
Quick Reply: How do you bleed the clutch
