Looking for steering wheel with elevated hub - option M018
Hi All,
I am looking for a non-airbag steering wheel with elevated hub - option M018. I have spent days looking but have been unable to locate one for sale. Can anyone here point me in the right direction?
I have also tried finding the correct part number, but that is proving to be quite a challenge as well. So if anyone can provide me with the correct part number it will also ease my quest.
Thanks!
Thanks!
IHI KING!
The part number is 964-347-084-02. Its on 403-05 #25 in PET. If you are looking for the RS steering wheel, its 928-347-084-08. Both are listed as M018 options.
Note: There are multiple colors available for the 964 part number.
M018 steering wheel hub
Is the M018 option including steering wheel or is it a seperate hub. I have a M431 steering wheel and wan't to add the M018 hub, is this possible?
I have the elevated hub, but I still found the steering wheel too far away, so I replaced it with a Momo "No 7" wheel that is closer, even with the standard Momo hub. The big advantage with a non-specific steering wheel, like a Momo or OMP is that it is easy to buy spacers and different hubs to adjust the reach distance.
You can swap the hub from one wheel to the same wheel. Drill, M6 bolts and nylocks.
The elongated hub is the same on the '85+ 944, this widens the search pool.
Some info here:
https://rennlist.com/forums/964-foru...ended-hub.html
and here:
https://rennlist.com/forums/964-foru...ing-wheel.html
Some info here:
and here:
