Heater bypass - definitive wiring solution
#46
Can I just do like what this guy did with the "Bridge adapter relay," in lieu of splicing all that junk?
That thread is for a 993, but I think it applies to the 964 as well, no?
#47
Finished my install. I am getting hot air into the left vent but as it moves to the right vents it gets cold. I dont think i have it seated in very well on the lower part of the bypass. Need to adjust when i get time. Do you think this is just a loss of hot air? or has anyone noticed a similar effect?
#48
#49
thanks sooner! I was born in Ada and my parents still live in Poteau.
#50
#52
#53
I did the wire trick first, and it work fine. Then I use the Bridge Relay now for 3 years everything work perfect.
#55
Mine is wired like Spyerx posted. Works perfectly. I wonder if this is a late model early model 964 difference and the way we used only works on the later MY cars.
Thoughts?
Thoughts?
#57
I have a 91, but the date on the little gold sticker in the door well says December 90. Not sure if that matters. I removed fuse and tried the Bridge Adapter Relay and the jumper method. Will try the purple wire method today and see if that finally works.
#58
my car is a 91, the purple wire method is what worked. Remove the relay, tap the purple wire, jump to that relay plug. Make it tidy. Worked for a year, no issues. I do get a no-fan error in the CCU codes though :-) But there is no fan.
