Intro and other shenanigans
#46
Since it was above freezing out today...finally! I decided to tinker around with the 964. Today's install was a Fabspeed Cat bypass. It was a super easy install, fit the way it should and it felt good to work on my car again.
pics
old cat
the two side by side, not much of weight savings that I noticed, maybe a few pounds
The new bypass in
I also replaced the hardware with new stainless steel bolts, washers and nuts. The old ones were pretty crusty.
pics
old cat
The new bypass in
#47
Time to beautify the car a little. Ever since I bought it the spoiler had split right in the middle and also had a crack on the one side. So I got another one from Ebay.
crack in the middle
crack on the side, after I had already pulled it off
old and new to me, but also old
for some reason the one I bought looks a lot smaller
new one on with no cracks!
next up is saying bye bye to the mirrors, I had bought a set of aero mirrors on Ebay a while ago and since it is no longer absolute zero outside, I can finally install them.
At this step I got out my buffer and compounded most of the marks from the original mirror out. Then I hit it with a swirl remover and here we are
This could be interesting looking
I did actually put both on, just no pics of it out yet.
crack in the middle
#50
Time to beautify the car a little. Ever since I bought it the spoiler had split right in the middle and also had a crack on the one side. So I got another one from Ebay. crack in the middle crack on the side, after I had already pulled it off old and new to me, but also old for some reason the one I bought looks a lot smaller new one on with no cracks! next up is saying bye bye to the mirrors, I had bought a set of aero mirrors on Ebay a while ago and since it is no longer absolute zero outside, I can finally install them. the two side by side At this step I got out my buffer and compounded most of the marks from the original mirror out. Then I hit it with a swirl remover and here we are This could be interesting looking I did actually put both on, just no pics of it out yet.
#53
The spoilers crack by design*. Here's a 5pg thread of cracked 964 spoilers. Your cracked spoiler isn't trash, people repair them. Your replacement will probably crack too.
https://rennlist.com/forums/964-foru...rack-here.html
*i.e. poor design
*i.e. poor design
#54
#56
mine was pretty easy to fix. i removed the black faring at the front of the car under the bumper. There are a couple metal tabs that the lower section bolt to. I used my pliers and bent them down and re-attached everything. Good as new and didn't take long at all.
before:
after (the one on the right):
before:
