964 Forum 1989-1994
Snow Mouse - an oldie 964 to compete with 997 Cups - maybe?
Old 07-30-2014, 05:32 PM
  #46
Lemass Automotive
Lemass Automotive's Avatar
No more rubystone
Old 07-30-2014, 05:50 PM
  #47
ThomasC2
ThomasC2's Avatar
Originally Posted by robt964
Not at all. It all adds to the very purposeful look.
The race cars used scews, they didn't have time to bother with the flimsy plastic clips in a race situation. So that look is just fine!
Thomas
Old 07-30-2014, 06:03 PM
  #48
perrew
perrew's Avatar
The Intrax 4ways comes with top mounts for the fronts shocks .ThomasC2 I dont run any spacers its all achieved with the inner and outer barrels of the 7Cup wheels, thats one of there distinct advantages.
Old 07-30-2014, 07:21 PM
  #49
mf_rsr
mf_rsr's Avatar
Originally Posted by perrew
PCCB Gen2 380/350
997Cup Calipers
993 Brake Booster
997GT3RS PCCB Brake Cylinder
Now ^^this^^ is new news and v.exciting :-)
What was involved here? Any weights? I've been researching this with Freno's carbon carbon set up and the gains look incredible when combined with rs hubs and bbs...please let us know the details!
Old 07-30-2014, 07:43 PM
  #50
mf_rsr
mf_rsr's Avatar
Great car btw - love it!
Centre locks as well? Did you use adaptors or convert everything over...
Old 07-30-2014, 07:52 PM
  #51
Bill Verburg
Bill Verburg's Avatar
@ThomasC2 thats a great writeup tks so much for that, two things I dont recall you get 30mm extra track and the ABS stuff Ive read up on a couple of times but I dont think weve changed that out, well be fun seeing if it works anyway?
The 993RS wheel carriers do not change the track width, they do change the rotor that is needed to on w/ a 993 o/s. 964 wheel carriers need rotors w/ 964 o/s. At least when Porsche/Brembo calipers are used
The wider track comes from moving the front suspension longitudinals from the inner mounting holes to the outer mounting holes. This increases track 30mm per side for a total of 60mm.
You can further increase the track if desired by switching from 964 to 993 longitudinals, when this is done in conjunction w/ the mounting hole change you get 42mm per dide for a total of 84mm increase in track width.
The change for 964 to 993 longitudinals alone increases track 12.5mm per side, for a track increase on 25mm
993 ABS wheel uses 48 teeth, 964 has 45 teeth, usually you use the 964 ABS wheel w/ the 964 ABS brain but sometimes when brakes or tire od is changed it's necessary to change that
Old 07-30-2014, 08:15 PM
  #52
Bill Verburg
PCCB Gen2 380/350
997Cup Calipers
993 Brake Booster
I'm very curious about this too, I've seen the 997 brakes adapted to 993 but not 964 and seen the 993 m/c adapted to 964 but am extremely curious about using the 997 m/c w/ the 993 booster, that would be a very desirable way to go.
Any pictures or details?
very nice car btw!!
Old 07-31-2014, 03:40 AM
  #53
ThomasC2
ThomasC2's Avatar
Ok, it's 25 mm then and I did say it is because of the 993 longitudinals and not from the uprights.
The ABS sensors on 964 are mounted in line with the brake disc, on the 993 they sit facing the disc from the side. Therefore the "meassurment teeth" at the end of the sensor will sit in the wrong direction over the ABS cogs if you use a 964 sensor. The 45 teeth 964 cog works just fine.
Thomas
Old 07-31-2014, 06:56 AM
  #54
perrew
perrew's Avatar
Tks a LOT for the cheers guys, great to read!!!!
Lots of great info coming in this thread Big tks to Bill and Thomas! Its very nice to have all this info in one thread.
We didnt change the Longitudinals, maybe this is worth doing I dont know?
Regarding PCCB weights on a 997 going from steels, 380mm fronts and 350mm rears, theres a 22kg difference. Im figuring I loose som 18-20kg due to smaller discs on the 964.
We used a 25.4mm Master Cylinder from the 997GT3RS but had to change the Brake booster from the 964 to a 993 booster. New Bells were manufactured. For the centerlocks the 964 hubs were used and modified. Its the good ones from the Cup cars not the ones from the 7RSs thats get loose.
Currently on vacation so I dont have a lot of pics to show at the moment but will try to remedy that later.
Old 07-31-2014, 07:54 AM
  #55
perrew
perrew's Avatar
One interesting thing Ive read about the amazing Roock 993GT2Evo cars are that they had an additional 7cm wider track compared to the works cars, does anyone know how they achieved this?
Old 07-31-2014, 08:37 AM
  #56
mf_rsr
mf_rsr's Avatar
Thanks for the info. Enjoy your vacation and then it would be great to get some pics and fitment notes up inmore detail...I have a brake issue to resolve asap and your approach seems perfect!
Old 07-31-2014, 09:52 AM
  #57
Bill Verburg
We used a 25.4mm Master Cylinder from the 997GT3RS but had to change the Brake booster from the 964 to a 993 booster. ...
That is great info, Do you know if it's a straight swap, 993 m/c to 997m/c,
That is a very desirable mod for lots of big brake setups and would help a lot of us to know for sure.
Old 07-31-2014, 09:58 AM
  #58
perrew
perrew's Avatar
Regarding the fit of the GT3RS master cylinder and the 993 mc we didnt do anything but change to the brake booster from the 993. If you look at the pics of the two M/Cs they look very similar, from my reciollection if you have 964 M/C you need to change the fittings.
As to how the feel of the cylinder is I cant tell how the larger cylinder feels with different Calipers etc.
Old 07-31-2014, 10:00 AM
  #59
Bill Verburg
beyond the longatudinals and mounting holes the next thing is wheel o/s and width and the camber adjustment shims
factory 993GT2evo used 10x18 ET32 wheels in front, a 10 ET28 would raise track by 4mm per side.
track for the factory GT2 Evo w/ the above wheels was listed as 1460mm in front
Old 07-31-2014, 10:04 AM
  #60
Bill Verburg
yes a 964 m/c is very different and cannot be used w/ the 993 vacuum boost can and vice versa
Most 964 owners that install a big brake kit also swap in the 993 vacuum booster and m/c(alternatively an electro-hyd setup as used on the RS and turbos can be swapped in, but that's a lot more work and expense)
The 993 m/c is 23.8mm, it would be very desirable to have a 25.4mm m/c in there.
Quick Reply: Snow Mouse - an oldie 964 to compete with 997 Cups - maybe?
