964 Forum 1989-1994
Flappy paddles for 964 Tiptronic.
Old 05-26-2010, 03:44 PM
Mc.Queen 964
Mc.Queen 964's Avatar
Default Flappy paddles for 964 Tiptronic.
Hi Guys.
Do you know if someone sell flappy paddles to screew in a normal steering wheel?.
And, Could I install a 993 Tiptronic steering wheel and leave it the steering wheel flappy paddles working?
Regards!.
Old 05-26-2010, 04:45 PM
mojorizing
mojorizing's Avatar
Here's a link to wher a 993 tip steering wheel was modded to work a radio.
http://p-car.com/diy/steeringradio/
It might work as a shifter, because I believe it's all electrical interface once you're in manual.
Old 05-26-2010, 04:47 PM
jimq
Burgled
jimq's Avatar
I seem to remember seeing one on here once that some vendor was selling for a 964. It was a few years ago tho.
Old 05-26-2010, 05:20 PM
mojorizing
mojorizing's Avatar
Jim,
I recall that also but I couldn't find it. It was a good write up with pro/cons on paddle versus stick. It was a few years ago.
Old 05-28-2010, 02:35 AM
roadsleeper
roadsleeper's Avatar
Here's another (pricey) option if you can't find paddles to retrofit to the OEM steering wheel:
http://www.fvd.de/de/en/Porsche-0/-/...cl.-AB%29.html
Old 05-28-2010, 01:13 PM
boxsey911
boxsey911's Avatar
A chap over our way who had a 993 speedster built from the ground up by using a 993 tip cab as a doner, has flappy paddles. All work done by Marc and Colin at Ninemeister:
Old 05-29-2010, 01:21 AM
curve lover
curve lover's Avatar
Default No affiliation
McQueen-- Similar to the above FVD reference, this is advertised by carAdventure.de as $2,580...
Here's design911.co.uk's Raid Daytona GT Steering Wheel, $1,500:
Here's a wireless system that might just possibly do the trick for ya: twistMachine.com's "Shrifter" -- a bolt-on paddle shifter, but only intended for pre-airbag cars. Starts at $540 USD. Good luck!
Old 12-17-2011, 02:26 PM
circleswim
circleswim's Avatar
Sorry to drag up an old thread but might as well add some info, I've got the works bell kit sitting in my bedroom, to be wired in over the winter... Only cost £199 for some lovely carbon paddles!
http://www.plays-kool.co.uk/acatalog/WorksBell.html
Old 01-07-2012, 01:17 PM
circleswim
circleswim's Avatar
Just to complete the story for anyone interested, I have finished installing my works bell paddle shift. I used the universal kit and just wired the paddles in parallel with the micro switches in the gearbox. Surprisingly easy job... Ignore the loose cable at the moment, it will be replaced with a tangle free spiral cable in time.
Old 01-07-2012, 01:33 PM
RicardoD
RicardoD's Avatar
Very cool
Old 01-07-2012, 06:02 PM
cockyapple
cockyapple's Avatar
Looks great.....a more in depth description of what was involved would be great if you have the time to post
cheers steve
Old 01-08-2012, 01:09 AM
B. Elliott
B. Elliott's Avatar
Wow! I just fell in love with that steering wheel. Which Nardi is it?
Old 01-08-2012, 02:36 AM
RicardoD
RicardoD's Avatar
+1 on in depth install details as well as Nardi wheel type
Old 01-08-2012, 08:46 AM
circleswim
circleswim's Avatar
No idea what Nardi wheel it is, I got it off eBay but I'm guessing it's pretty rare as I've not seen another for sale. The works bell paddle shifter came from Luke at plays kool, who I can't fault, his help/service is second to none.
As for the install, I started with a non airbag steering wheel so started by pulling off the horn pad on the wheel pictured below:
It's held on by 3 clips so just pull it towards yourself whilst sat in the drivers seat using one hand either side of the horn pad being careful not to damage it.
Once the horn pad is off, remove the 15/16 nut securing the wheel, mark top dead centre and remove the wheel.
Fit the steering boss, in my case a momo boss with a driftworks adapter fitted to it to accommodate my nardi wheel's bolt pattern. The works bell shifter (pictured below) fits behind the steering wheel using the longer bolts supplied with the paddle shifter.
With the steering wheel fitted I set out removing the centre console.
You need to remove the two front switch panels at the top.
Underneath them are 2 Philips head screws. At the back of the console there
is a little pad which pulls out. There are then two screws to be removed
from there. There is then one screw underneath the handbrake. This shall
then release the plastic cover which is removed by pulling along the
handbrake. Then there are two screws at the back of the centre console two
in the middle. There is also a bar which goes across beneath the handbrake
again this needs unscrewing. Finally on the gear lever the push button needs
unscrewing just by hand and the gear lever then just pulls off. Then centre
console should then just pull straight up and off.
Once the centre console is removed you can see the microswitches for the gearbox.
I decided to stay away from the switches and instead wired into the connector further down the loom...
The wiring for the shifter is simple. You have 2 cables for each paddle on the works bell shifter, one is an earth/common and the other is the switch signal, it doesn't matter which is which but choose 1 from each paddle to be the earth, these need to be spliced together to give 1 cable for the earth path. You need to extend the switch cables and earth cable from the paddles with enough cable to reach the gear shifter. This leaves you with a loom of 3 cables to be routed through the dash to the gear shifter where you need to splice the following cables:
Brown - earth
Brown red - downshift
Brown yellow - up shift
Once connected, test the paddles (they only work with the box in manual mode) and refit the centre console.
Et viola
Old 01-09-2012, 03:07 AM
nirich
nirich's Avatar
Those flappy paddles look great!
But, I have a few questions…………………..
Presumably the thickness of the paddle “ring” is about 20mm and therefore puts the steering wheel that much closer to your chest?
Do the indicators still self-cancel? As it seems that the thickness of the flappy paddle moves the part of the wheel that turns the indicators off further away.
When driving is there any difference is speed/smoothness/ease when changing gear compared to normal tiptronic gearshifts?
TIA
Quick Reply: Flappy paddles for 964 Tiptronic.
