The best Starter for the 951
Old 03-17-2017, 04:58 PM
kyle951
kyle951's Avatar
Default The best Starter for the 951
What is the best starter for our cars? I have had issues with both of my stock Bosch units and would like to try something new. Please let me know if other owners have had better luck with a different brand of starter.
Old 03-17-2017, 05:04 PM
V2Rocket
Rainman
V2Rocket's Avatar
What issues have you had?
Can't think of anyone ever complaining about the starter before.
There is an aftermarket unit available that is smaller/lighter.
http://garage.ideola.com/prod-ElectricsUpgrades.html
odonnell
odonnell's Avatar
Edit: damnit, posted that at the exact same time
Old 03-18-2017, 12:27 AM
KVDR
KVDR's Avatar
Do you use the starter heat shield?
Old 03-18-2017, 04:40 PM
kyle951
kyle951's Avatar
Guys, I appreciate the input.
The problem that I am having is that about every 6 or so times I start the car I end up getting a slight hesitation and then the car turns over. I have checked the battery and terminals and everything checks out fine. I even checked the ring gear to see if it was possibly the cause.
I have the same Bosch starter on my 87 951 and it has never given me this type of problem. I am still checking some things trying to diagnose the problem.
Also. I did look at that IMI starter and would consider it if it truly helps.
Old 03-18-2017, 05:17 PM
KVDR
KVDR's Avatar
Are you getting starter 'kick-back'?
Is your bellhousing completely slotted under the speed and reference sensors?
There was a Porsche technical bulletin about this.
http://forums.pelicanparts.com/uploa...1288240378.jpg
I'm installing the updated sensor bracket with sleeve and hopefully this will solve my 'hard starting'.
Old 03-18-2017, 09:08 PM
NCLA951
NCLA951's Avatar
Once in a blue moon I'll get starter kick back, even with the sleeve and no slots. Had no idea what it was for a while, and didn't happen enough to warrant worry.
Old 03-18-2017, 10:54 PM
mharmon944
mharmon944's Avatar
what's the part number for the sleeve? anyone know?
Old 03-18-2017, 11:42 PM
KVDR
KVDR's Avatar
944.101.320.00 - Sleeve
The updated bracket has clearance for the sleeve, so you need that part too. 944.101.321.07
You can see the difference between the two. The new one also has an extra 'B'.
Old 03-18-2017, 11:45 PM
KVDR
KVDR's Avatar
Order #21 also - 900.197.047.08
Old 01-29-2019, 11:10 AM
shortyboy
shortyboy's Avatar
Has installing the updated bracket with sleeve solve your issues? Currently trying to fix my intermittent start issues with VEMS. Thanks
Old 01-29-2019, 08:22 PM
KVDR
KVDR's Avatar
Yes, the updated bracket and sleeve completely solved the hard starting and kick-back I was suffering.
Old 01-29-2019, 08:29 PM
shortyboy
shortyboy's Avatar
Great to hear! Did you install new bracket in car or with motor out and how hard was the install and sensor gaping?
-Wayne
Old 01-30-2019, 02:28 AM
KVDR
KVDR's Avatar
-Wayne
Engine in car, but I had the intake off. The hardest part was loosening up the socket head bolts - I believe I had success using three extensions from under the car along the bellhousing. I replaced these bolts with standard hex-head type on reassembly.
Gaping wasn't a problem using a thin washer temporarily glued to the sensor. It is pretty tight in there though, and I was almost certainly swearing.
Old 01-30-2019, 10:42 AM
mahoney944
mahoney944's Avatar
-Wayne
Turn the motor to tdc and install the sensor with the washer to set the gap, tighten down the bracket applying light pressure to bracket preventing it from moving away. Remove washer from the sensor. Probably wise to replace both sensors while your in there since they are a know weak point on our cars. Much easier to do with the intake removed.
Quick Reply: The best Starter for the 951
