sound deadening removal
got a bit bored this weekend waiting on parts, and I still have some of the sound deadening on my floorboards, so I decided to remove.
did a combo of dry ice and heat gun and all the big chunks are off. any suggestions how to clean up to bare metal? I want to hit it with some primer. This will lead to a full respray of the inside of my race car.
MEK saturated rags....soak some old rags with MEK and place them around the floor.
Keep both doors open and a fan feeding fresh air through the car.
When you have to get in to handle the rags and do the cleanup of melted material, wear a respirator.
Eventually, you'll just be mopping up a liquid sludge.
T
T
Why do you want to get it to bare metal? There is already primer underneath the sound insulation.
I wouldn't wire brush it. You'll not only remove the primer, but probably remove the galvanizing. It would also make a mess of the insulation and make all sorts of dust.
Short answer is that I removed my dash and now I want to respray the inside of the car. I don't car to strip the primer. That's good but I want to get all the goop off I can
