SSI New Ball Joint Kit
Old 02-05-2014, 11:07 PM
SSI Performance
Former Vendor
SSI Performance's Avatar
Default SSI New Ball Joint Kit
Over the years there have been many aftermarket Ball Joint kits produced for the Porsche 944 that copied the factory design including its flaws. This revolutionary design increases the strength & adds new features not found on any other 944 joint.
New & improved features;
• New alloy steel
• Overall joint geometry
o Increased radii
o Shoulder to distribute load
o Pinch bolt slot size
• Flats used for alignment
• New lower cap with joint tension adjustment bolt, locking nut & Zerk fitting
Kit cost $250
Old 02-05-2014, 11:15 PM
Pauerman
Pauerman's Avatar
Was wondering when you were going to let this out of the bag!
Looks great Sloan.
Old 02-06-2014, 01:13 AM
944meister
944meister's Avatar
Looks like I'm rebuilding my ball joints this year
Old 02-06-2014, 10:33 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
• New alloy steel
o Increased radii
Kit cost $250
How much more boost can I run with this mod?
Old 02-06-2014, 10:43 AM
reno808
reno808's Avatar
LOL at Chris W.
Old 02-06-2014, 12:44 PM
lart951
Basic Sponsor
lart951's Avatar
How easy is this kit to install? any special tools needed?
Old 02-06-2014, 12:53 PM
Chris White
Rennlist Small
Business Sponsor
Sorry - Special Tool is no longer available.
Old 02-06-2014, 01:18 PM
RajDatta
RajDatta's Avatar
Can this work on 968 control arms? I know they are somewhat different.
Old 02-06-2014, 01:42 PM
lart951
Basic Sponsor
lart951's Avatar
The only visible difference I have seen between the 968 arm and turbo is the tab for the brake cooler ducts otherwise I believe the ball joint is the same
Old 02-06-2014, 02:10 PM
Thom
Thom's Avatar
The ball joint assembly on the 968 arms cannot be released through a clip like on 944 arms because the whole bottom of the joint is "sealed".
Old 02-06-2014, 02:38 PM
shortyboy
shortyboy's Avatar
lmfao
Old 02-06-2014, 03:14 PM
SSI Performance
Former Vendor
Thanks Vic, Had to do testing on them now there in production have the first batch ready next week.
Looks great Sloan.
Old 02-06-2014, 03:15 PM
aglaes
aglaes's Avatar
How/where do you order the kit?
Old 02-06-2014, 03:17 PM
SSI Performance
Former Vendor
There's always a wise guy in the group
Old 02-06-2014, 03:27 PM
SSI Performance
Former Vendor
Once you remove the arms you will need a flat blade screwdriver, Pick, drill W/1/8 bit, snap ring pliers, 8mm Allen socket, 14mm wrench, torque wrench & grease gun.
Quick Reply: SSI New Ball Joint Kit
