Winter project under way. Updated 01/07
Old 01-04-2009, 02:05 AM
95ONE
95ONE's Avatar
Originally Posted by hp18racer
Amazing how many details to be worked to make a race car, you've got a lot of hours of work ahead! I'd really like to see pictures of what you do with the nose.
Will you be club racing it with PCA?
I don't even know what I'm going to do about the heat exchanger nose bracket. Radiator, oil cooler, Intercooler.
I keep looking at other forums and other builds to get some ideas. nothings really jumping out at me right now. It will probably be all Aluminum with a strong Cross-bracing attidude. Mixed in with a bump bar and body support tabs. It will be a slide on/off piece secured with two verticle bolts for ease of access. Many cues will be taken off the Lindsey racing bracket, - yellow race-car - but about 1/2 the weight of theirs. The stock steel piece I cut off was 23lbs. The Stock bumper was 24lbs. The aluminum tow bar was 8lbs.
The new GT bumper I think is 12lbs, (Still need one if any of you are selling used) and the new bracket should be around 10lbs. A significant weight loss off the furthest point of the car. 30+ lbs.
Fiberglass Doors arent in the budget this time around. But will net me another 50lb savings! And that is where I plan on offsetting much of the Cage weight.
My Brakes and (inexpensive) wheels and tires will unfortunately be adding around 10lbs per corner... ouch
Club racing is still a hope. I need to sort the car to some point of reliability before I start racing.
333pg333
333pg333's Avatar
Thread subscribed!
Also Bruce, have you finished your trans brace development? Is it fine now?
Old 01-04-2009, 02:13 AM
95ONE
95ONE's Avatar
Originally Posted by 333pg333
Thread subscribed!
I feel confident I can lose the broken driveshaft worry. Although I think I will probably Add a solid trans mount.
Old 01-04-2009, 02:20 AM
gt37vgt
gt37vgt's Avatar
yeh I'm sure the trans mount is great until your cut a couple of feet off the back off the car
Old 01-04-2009, 02:22 AM
blown 944
blown 944's Avatar
Old 01-04-2009, 09:37 AM
jlturpin
jlturpin's Avatar
Looks like you are well under way. Since you have your turbo setup off, you could just send it to me to test......
Old 01-04-2009, 02:26 PM
Acetylene
Acetylene's Avatar
Very cool project. I wish I had the time/money. I believe this is exactly the way I'd spend it. I will watch this daily for updates - good luck with this project.
Old 01-05-2009, 02:24 AM
95ONE
95ONE's Avatar
I didn't get to be at the shop long today. But here are some updated and pics.
Please. no ribbing about the rims. I know they look like they came off a Hot Wheels car. But they were only $400 for all 4. and they were 10.5" wide. Quick fix until later.
I got the Driver rear fender off. This is just the tip of the iceberg as far as cutting is concerned. Looooong way to go. Complete rear is going away and other fender side of course. and much of the roof. Glass Quarters are going to be lexan.
Problem is, we placed the GT widebody rears against the car. Man. they don't look like they're going to come even close to fitting. Not very happy. Going to have to make them fit. in the end, no one will know, but damn it's going to take another weeks worth of work. This is why projects always take double the time they're suppose to.
Probably won't have any updates until Thursday night.
Just for a quick idea though. The fender part pictured is 21lbs. the one going on is 9.
Old 01-05-2009, 02:57 AM
Ballistic-Chapman
Ballistic-Chapman's Avatar
Can you elaborate on the GT fender fitment issues? Some pictures would be great also
Old 01-05-2009, 12:54 PM
Weston Dillard
Weston Dillard's Avatar
Bruce,
Those wheels are really something! (couldn't resist) Man you are going nuts. Good luck with all that. What's your timeframe goal for getting it back together?
West
Old 01-05-2009, 01:13 PM
DanR
DanR's Avatar
wow that fender is a lot of work for 22 lbs saving
Old 01-05-2009, 02:03 PM
PorscheDoc
PorscheDoc's Avatar
Have you gutted the stock doors? If you remove the windows/hardware, and cut off the inside panel (roll the edges in), the door ends up weighing very little.
Old 01-05-2009, 02:20 PM
95ONE
95ONE's Avatar
I've done all that. Doors still weigh in at 36lbs ea. Fiberglass with inside panels and latching hardware should be around 15lbs. (estimate only from all the other fiberglass doors we've installed)
40-50lbs savongs is huge.
Old 01-05-2009, 02:23 PM
95ONE
95ONE's Avatar
I will take pics. But in all comparisons, the other 10 fiberglass panels I've installed on varying cars didn't come close either. So these are really just on-par.
Old 01-05-2009, 02:26 PM
95ONE
95ONE's Avatar
Originally Posted by Weston Dillard
Bruce,
West
You're allowed
Around march.
EDIT: LOL! lost an income at the home, so.. March of 2010 is possible?!
Quick Reply: Winter project under way. Updated 01/07
