944 & 944S Forum 1982-1991
Teledial centers
Old 12-31-2016, 06:03 PM
Ashman
Ashman's Avatar
Question Teledial centers
Hi all,
My apologies if I'm posting an existing topic. Searched to no avail...
It's obvious that my teledial centers had a black background on the Porsche badge that has since worn away.
I'm considering re-painting them.
First off, how do they come off? I see two little holes. Do I just insert two small screwdrivers and twist? Is there a special tool?
Secondly, I see a lot of them without any black in the background at all. What is "normal" for a 1986 944 lux?
Old 01-01-2017, 08:40 PM
jhowell371
jhowell371's Avatar
To remove them you need something (they make a tool) to hook behind both of those holes and pull straight out. Can't help with your paint question.
Old 01-02-2017, 04:10 AM
mel_t_vin
mel_t_vin's Avatar
Originally Posted by Ashman
It's obvious that my teledial centers had a black background on the Porsche badge that has since worn away. I see a lot of them without any black in the background at all. What is "normal" for a 1986 944 lux?
Normal...silver monochrome center caps on silver teledials.
If your car had painted/colored center caps, they were most likely added, after the fact, by a previous owner.
Old 01-05-2017, 12:10 PM
dmjames
dmjames's Avatar
Alternately, if you take the wheels off the car, you can just push the caps out from behind.
Old 02-09-2017, 01:24 PM
beamishnz
beamishnz's Avatar
This is the best way
Old 02-15-2017, 07:29 PM
Roka
Roka's Avatar
You can use any thin L shape tool such as a small hex key or a hose puller and just pull it straight out.
This thread has a nice example of rejuvenating the center caps.
https://rennlist.com/forums/924-931-...urrection.html
Old 02-19-2017, 02:32 PM
Ashman
Ashman's Avatar
Default Thanks
Thanks for all of the responses. I just used a piece of bent coat hanger wire to pop them off and then followed the procedure you linked to Roka.
Got 'em shiny and new looking and back on the car in a matter of a couple of hours.
Rennlist FTW again.
Quick Reply: Teledial centers
