illuminated window switches
I ordered a set of these and have no clue how to install them. I thought they had come with instructions but can't find them. If anyone else has ordered a set of these and can shed some light as to install tips it would be appreciated!
Uh, If you have a new set you haven't installed and you can't get instructions; I'll be happy to take them off your hands for what you paid and struggle to somehow make them work. If you are compelled however to keep them, the instructions I think, are available from Hans, the developer of the system.
You really don't want to install them. Seriously. Don't do it. Your car will likely go up in flames, as they cause premature failure of the fuel hoses, are a leading contributor to TBF(even in manuals) and have been known to cause head gasket problems.
I'll take them off your hands for $1.00 higher than whatever Ninespub would offer you.
Instructions are here:
http://www.designpaulchampagne.com/S...tallation1.htm
I'll go all the way up to $5 over, and will throw in a bunch of assorted nuts & bolts that I've recently removed from my '82.
Sorry Itoolio or Matt diGregory, but your negative post against me won't last you long on my pages! I did send you, after your purchase, a PDF file with instructions on how to install these switches as I did with the guys that purchased these. You never send me any other request on the instructions but again, whining around and trying to make me look like an a....
Sorry, but don't expect me to respond to you.
Just tried to insert the file here but for some reason unable to. I will try to send it via pm
Rich
Rich
Hey Rich. Just an opinion, but I'm pretty sure Itoolio's comments about fires and TBF, etc. were a tongue-in-cheek way (as was mine) to convince Matt to not install the switches because WE wanted them. In each case, we thought they were the NLA flat panel and back-lighted ones designed by Hans and Paul Champagne, but also, as a service to the OP, suggested where the instructions may be so that he could install them. If you re-read our posts, we were even bidding against each other in jest until Jetson posted the pic of the actual ones you sell. I don't think there was any harm or desire to make you look like an a.. intended. Just sayin'.
thank you for sending them Rich. The negativity wasn't a result of the request for instructions. If you don't know why...then you should take care of your customers! I never made any negative posts on "your pages" but you removed me from them any way. Poor customer service results in poor customer feedback.
