Steering Sleeve/ Shaft
It would also be helpful to heat the column with a heat gun,
put the bearing into the freezer ,
use the backside of a socket to drive it in,
use the extension installed from the nut side .
NOTE the internal bore must be round and nick free ,
if its not smooth then the new bearing may not drive in before being damaged.
use a file and or Emery cloth to make it smooth
Team Owner
OK please take a few pictures of the column mounting area.
if the mounting area is not perfectly round the bearing will not go in
Team Owner
OK it looks like the outer layer of the old bearing is still inside the column,
take a vernier caliper and measure,
there should be a very close difference from the ID to OD.
the bearing housing will crack apart its very brittle based on the info you have provided you have not removed the bearing outer surface
Team Owner
thats why it wont fit,
otherwise the bearing will start into the bore about 2 MM then you tap it home
Wow Merlin I would have never thought. Maybe because of initial investigation everything was so covered in grime and dirt but it totally makes sense now. I will remove it and try again. Lifesaver yet again!
