Steering Sleeve/ Shaft
Did some research and ordered a steering sleeve to fix my play in the steering wheel. First odd thing occurred when I realized that the steering wheel nut was barely finger tight. Steering wheel came off and it just seems like I may be missing something in there. Then I noticed that a sleeve is already on he shaft but it seems to have come out a bit I don't think it's in far enough. Pictures do more than words so here it is. Am I missing components and was the steering sleeve too far out? I pulled the sleeve out with barely any force just using a hook pick.
Team Owner
First has any work been done to the steering rack?
if so its possible to not have the coupler on enough,
this will push the steering shaft away from the horn ring.
Otherwise the bearing appears to have failed ,
and thus a new bearing should be fitted.
NOTE get a helper with the vacuum cleaner and sharp chisel,
strike the bearing a few times and it will shatter the outer metal bearing,
use the vacuum held close to suck out the ***** so they dont fall down the column
http://www.pelicanparts.com/More_Info/PEL-ML-STR.htm
Team Owner
no, you need a new bearing,
its called the upper steering column bearing, Roger sells them.
once you have it installed then the collar you have is pushed down the shaft into the center of the bearing.
then you put the steering wheel nut on the shaft,
then with vice grips pull the nut to the back of the car,
this will compress the shaft spring and let the E clip slot move upwards,
so your helper can slide it in to hold the collar in the preloaded position.
These bearings usually break from people pulling on the steering wheel while in the entry/exit mode,
or while trying to push the car with the steering wheel.
Loosen the collar and slide the switch down the steering column until it is just making contact with the horn ring.
That should fix it. If you had a failed bearing your steering wheel would jiggle and the horn would go off randomly when steering.
No, it's the horn contact on the multi switch sitting a bit too close to the steering wheel.
Team Owner
It would also be helpful to heat the column with a heat gun,
put the bearing into the freezer ,
use the backside of a socket to drive it in,
use the extension installed from the nut side .
NOTE the internal bore must be round and nick free ,
if its not smooth then the new bearing may not drive in before being damaged.
use a file and or Emery cloth to make it smooth
