928 Forum 1978-1995
Sponsored by: 928 Specialists
I don't think my coolant is circulating !!!
Old 03-27-2015, 05:45 PM
19psi
19psi's Avatar
Originally Posted by super928
I allowed the engine to idle about 15 minutes, some air bubbled out of the reservoir with the cap off. The temperature on the top hose is 165 degrees and the bottom hose temperature is 127 degrees. When I put the reservoir cap back on the temperature went up to 172 at the top hose and 135 at the bottom. But when I shut the engine off you can hear the the coolant bubbling in the reservoir. Now the low coolant light is on.
Sent from my iPhone using Rennlist
You got air in the system and it's belching it out. You're low on coolant now because you had air taking up its place.
Do what Mrmerlin told you up above and it should be fine.
Old 03-31-2015, 04:29 PM
super928
super928's Avatar
I removed the engine freeze plugs and little debris came out but it's still not circulating correctly. Any ideas guys ? (besides the water pump)
Old 03-31-2015, 05:03 PM
linderpat
linderpat's Avatar
Received 2,250 Likes on 1,254 Posts
See my post above. I think you have a clog. Maybe run the hose through the block (with engine off) before re-installing the block plugs and flushing, but otherwise, flush it thoroughly.
Old 03-31-2015, 05:13 PM
FredR
FredR's Avatar
What grounds do you have to believe the water pump is OK? If the system is full and bled correctly the only things that can stop coolant circulating that I can visualise are a failed closed thermostat [not likely in this case] or a water pump that has lost the impeller.
If the coolant is puking from the reservoir a sure sign that coolant is not circulating suggesting the WP has gone. Apologies if I am missing something here.
How old is the current water pump? I did not see anything suggesting this has been changed.
Rgds
Fred
Old 03-31-2015, 06:24 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,254 Likes on 1,247 Posts
if you follow the advice i posted your cooling system should be working as it should ,
UNLESS you have a failed water pump.
The stop leak will only fill in small occlusions in the cooling system ,
If you were to examine a head gasket,
you will find the holes are smaller to the front and get larger to rear of the head,
thus to make the cooling system work.
please report your findings after doing the filling and driving sequence I posted
Old 03-31-2015, 06:30 PM
SeanR
SeanR's Avatar
.... wrong post
Old 04-01-2015, 06:43 PM
super928
super928's Avatar
The water pump was replaced about six years ago. So it's probably time to replace it again. I'll flush it once again and if there's no improvement I'll replace it and the timing belt. Who makes the best water pump ?
Old 04-01-2015, 06:52 PM
rcwkr
rcwkr's Avatar
Default Had a very similar problem.......
My first 928 was a badly neglected '79 euro. It's first and most pressing problem was nearly immediate overheating. I had the radiator professionally cleaned, actually ran a mixture of gasoline and water through the cooling system, because the radiator had developed a leak between the oil and water cooling "compartments" in the rad. None of this helped. I figured that the water pump wasn't circulating the coolant at all, and began the process of replacing it. Turns out that the pump was new, as was the timing belt driving it. It had just not been installed with enough tension to drive the pump.
Old 04-01-2015, 07:13 PM
super928
super928's Avatar
Thanks I'll check for belt tension also.
Old 04-02-2015, 02:14 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Pull the thermostat and put it in a pot of boiling water. Also see if the rear thermostat gasket is there and in good shape. I've got mixed feeling on changing water pumps because of age.
Old 04-04-2015, 03:26 PM
super928
super928's Avatar
Gentlemen Thanks for all your advice!!!
I flushed my coolant system two times today and removed the freeze plugs and I'm Happy to say that it's circulating Correctly !!!
Old 04-04-2015, 06:56 PM
Ladybug83
Ladybug83's Avatar
Nice! Good job !
Old 04-04-2015, 08:27 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
What freeze plugs?
Old 04-04-2015, 08:38 PM
super928
super928's Avatar
Sorry ! Block drain plugs !
Quick Reply: I don't think my coolant is circulating !!!
