Our 6-speed Project
#227
Developer
Makiing the Speedo work on early 928's after the trans swap
Good information about the GPS pulse generator for the early cars:
http://www.summitracing.com/parts/atm-5289
Download and read the operating instructions. Seems very simple and straight-forward.
Again, this is only to make the speedo work after the trans swap on 1990 and older cars. On 928's from about mid-90 and up, your speedometer will work as-is after the trans swap as it gets its signal comes from the ABS system.
#229
Archive Gatekeeper
Agreed, I think the changeover was in '90, and there's a lot of heterogeneity within 1990- I think they were just using up leftover older parts. Only way to be sure is to look at the back of the diff...
#230
Developer
I agree... I will correct my earlier post to be more accurate.
My point remains the same: if your 928 is relying on the pulse from the differential to drive the speedometer, it is not a insurmountable problem. We are not the only ones swapping in later transmissions into early cars.
The solution exists, is not expensive, and not hard to install or set up. Reading the reviews on the link is helpful.
#233
Carl I applaud your rear crossmember design. That is such a great idea not having to remove the rear suspension in doing a transmission repair. Have you given any thought for extending this product to cars that have stock transmissions?
#234
Developer
No, I have not. I have a 3-piece engine cross-member that I thought was going to be a big hit - allows you to service oil pan gaskets and rod bearings without removing the front suspension. Works really well! But has sold only so-so. I would think that a 3-piece rear cross-member by itself would sell even lessfrequently.
Two cross-member/kits I am working on though: To convert the 4-speed automatic 928 to a 6-speed manual; and to convert the 4-speed automatic 928 to a 6-speed auto with paddle shifter.
#237
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Carl, I saw on your site the kit is specifically for the ZO6 manual transmission. You had mentioned above too that you are working on a kit to roll an auto 928 over to a 6L80E 6-speed auto. Will this kit work with the 4L60E 4-speed auto from the C5? Also, will the torque tube still have to be sent in for modification?
#239
Developer
Which one is mine?
do you paint or powder coat the steel parts?
#240
So this 6 speed auto with my supercharger would be a good thing I am thinking.
