928 Forum 1978-1995
Sponsored by: 928 Specialists
The cheap part of powder coating is the actual coating!
Old 02-05-2013, 10:40 PM
worf928
worf928's Avatar
Received 1,543 Likes on 1,007 Posts
Originally Posted by GregBBRD
....it's the process that we use to put it all back together that sucks up the hours.
And let's not forget all the other stuff:
- 'thinning down' the PC around the bore for the flappy's shaft so that it will actually turn freely
- taking the PC off the sealing surfaces for the sensors on the water bridge and the bottom of the bridge (so that the TEMP-II doesn't lose it's mind.) And then testing the ground path with real current.
- chasing every threaded bolt hole
- roughing the mating surfaces for the hoses to the water bridge so that they'll seal
- getting 'lumps' off of the sealing surfaces for the runners and plenum side plates
And probably a few more that I've blocked from memory.
Old 02-05-2013, 10:42 PM
SeanR
SeanR's Avatar
I think you've covered it. Not to mention if the customer wants colors to the letters.
My Mac guy had a chore to get me the right tap/die to clean up the sensor holes. You'd think that would be an easy one.
Old 02-05-2013, 10:52 PM
worf928
worf928's Avatar
Compared to the wacky taps and dies you need for a 16v motor the 32v is easy. This was the only place I could find that had what I needed. (Weird that they are on my way home (sorta) from my real job. But they ship too...)
http://www.hdchasen.com/
That's the easy part: I hand them the intake and say "go to town."
When I did the letters on my '89 it took me 10 hours of roughing, masking, and multiple coats of color and clear. Maybe there's a quicker way of doing it and not having it look like a drunk college kid on summer vacation, but I never bothered to find out.
Old 02-05-2013, 10:54 PM
SeanR
SeanR's Avatar
Thanks for the link
I swear, I have a steady hand on almost everything. I can put a bullet on target out at long range but put a paint pen or a magic marker in mine and the letters I try to color look like I have a bad case of palsy. If the customer really wants it done here, I give them to my daughter.
Old 02-05-2013, 11:05 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,254 Likes on 1,247 Posts
Yeah,
the Chells are back.
Along with washing the intake with very hot water and simple green after PC has been done
I`ll add this to the mix
The other prime component that needs special attention is the crank,
say you send your crank to just be polished,
well it comes back all clean and shiny,
Now the fun begins,
you stick your barrel cleaning brush into the oil holes and it comes out with black paste,
this is the polishing compound,
it has neatly filled the oil holes in the crank,
and if its not removed well your gonna have a rod knock in about 10 mins after it starts.
The ideal way to clean the crank is to drill out the oil plugs on the throws then tap them to fit a screw plug.
once the plugs are removed then cleaning the traps in the crank is easy.
NOTE you may have to balance the crank after fitting the screw plugs.
NOTE spray the crank with WD 40 after the final cleaning cycle.
Otherwise use atleast 3 cans of brake cleaner to flush out the oil lines,
I use one can to flush then wash it with simple green then very hot water flushed in, then blow dry it.
Then start with another can and I repeat this 3 times till the cleaner washes clean.
Oh lets not forget about flushing out the oil ports in the heads,
and making sure the anti siphon valve seats are green loctited and staked into place
Old 02-05-2013, 11:06 PM
Lizard928
Lizard928's Avatar
I have done tons of cars now......
Yet to have one issue. I normally pressure wash the inside of the manifold with a 3500PSI washer first, then I take a pick and do a little scraping, then I pressure wash again.
I can fully clean an intake and valve cover combo in about 45 min.
I chase all threads with tap and never seize to catch all particles in there. I also have never had trouble with the Temp II sensor as the surfaces that mate to the head remain clean.
Old 02-05-2013, 11:07 PM
SeanR
SeanR's Avatar
Get Simple Green out of your inventory of cleaners Stan. It does nothing but corrode things. Get to the local Lowes and pick up a bottle of Formula 88 degreaser. Works 10x better and no after effects.
Colin, I power wash/high pressure water spray, soap with a long brush or two, spray again, force air dry and follow up with the same again.
Old 02-05-2013, 11:16 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
I`ll look into that Sean
Old 02-05-2013, 11:39 PM
Jhoffmann
Jhoffmann's Avatar
Wink
Everyone is always talking about how "cheap" they got their powder coating done. When I do this for a customer, it is really expensive....but the expensive part isn't the actual powder coating....it's the process that we use to put it all back together that sucks up the hours.
I get to see a lot of engines that are turned into absolute scrap metal, from this process. From cheaper older engines that people are trying to make look better to a high end Devek stroker engine. Poor preparation, poor workmanship, doesn't discriminate.
Here's why. These pictures are of a manifold that just came back, from powder coating. We blew it out, first, and them started "picking" in the corners to get all the debris out. This is a picture during that "scraping process"
And I poured what I could, onto a plate, to give you an idea of how much debris gets caught up above the venturis.
Remember, this is from one manifold that was blown out throughly!
Now, how much did you pay?
Greg,
Is that my intake?
Old 02-06-2013, 12:56 AM
Ed Scherer
Ed Scherer's Avatar
This all reinforces my belief that:
  • I got really lucky to have found a great PCer on my first try; and
  • I was not being a jerk to give my PCer very detailed instructions on how to do masking; and
  • my hours spent on research and writing up those detailed instructions for the PCer were well worth it.
Remember that thread I started "Powder coating intake/cam covers/etc. best practices (for the zillionth time!)" 2+ years ago? And the resulting guide to give to your PCer? In retrospect, it really was worth it, as I had none of these problems. Zero. And I'm hoping that anyone else who read that thread and has used that guide since then has likewise gotten good results.
I got zero material out of anything that I got back from my PCer when I tried washing it out / swabbing it / etc.
I had almost zero work to do to the parts after I got them back. IIRC, there was just one really minor area on one of the mating surfaces that I had to razor off. That's it. Less than five minutes. The PCer followed the guide really well; didn't have any coating in any of the holes. No thread chasing necessary.
And the results were pretty damn stunning, IMHO.
Old 02-06-2013, 02:13 AM
danglerb
danglerb's Avatar
Nobody is really using a tap to clean the threads right, only a thread chaser? Taps cut on every pass so the fit is less and less tight.
Old 02-06-2013, 02:16 AM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,452 Likes on 1,459 Posts
Originally Posted by Jhoffmann
Greg,
Is that my intake?
Yes, it is. Keep in mind that I "rejected" it the first time and they had to "blast" it a second time and re-powder coat it. It's beautiful....but had the media packed into the corners something fierce.
It's going through its' third cleaning, tomorrow morning. Another round of scraping with dental tools and then a pressure wash and blow job.
The shop mantra:
If you don't want to lick it, it's not clean enough.
I end up doing this all by hand. I'm afraid that hot water (I've got an industrial hot water parts cleaner) or chemicals will discolor/damage the powder coat color.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 02-06-2013, 02:25 AM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
In California, the guys doing the powder coating work can't speak English, much less read it.
And the people that run the place have taken in so many industrial fumes, over the years, that I'm happy when I get back a 928 intake manifold and not someone's Harley engine cases....
I'd do better sending a note to Santa Claus.
Old 02-06-2013, 02:26 AM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
Jhoffman, if that's your black GTS at Greg's right now, all I can say is
That is one gorgeous, pristine car. With intake soon to match, looks like.
Old 02-06-2013, 09:20 AM
depami
depami's Avatar
.......... I'm afraid that hot water (I've got an industrial hot water parts cleaner) or chemicals will discolor/damage the powder coat color.
What about ultrasonic cleaning?
.......... blow job .......... shop mantra .......... want to lick it .......... all by hand .......... I'm afraid ..........
Quick Reply: The cheap part of powder coating is the actual coating!
