928 Forum 1978-1995
Sponsored by: 928 Specialists
Battery Ah rating
Old 09-02-2012, 07:04 PM
Leon Speed
Leon Speed's Avatar
Default Battery Ah rating
Please excuse my electrical ignorance
I think the rating for my MY is 72Ah. I am looking at two batteries, Bosch S4, 74 Ah/680CCA and Bosch S5, 77 Ah, 780 CCA.
Is it ok to use a (slightly) higher Ah rating?
Old 09-02-2012, 07:05 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Sure..wont be a problem at all...I would think
Old 09-02-2012, 08:36 PM
mark kibort
mark kibort's Avatar
the amp hour rating is the capacity. think of it like the battery fuel tank size.
the cold cranking performance is the internal resistance of the battery which allows for the amount of current it can dump at one time, cold or hot.
this why i can run a odessy battery with 14 amp hours of capacity, and take adantage of its near 800CCA current dump potential. the difference, is that it cant dump 800amps for very long.
example. 14 amp hour battery can dump 28amps in a half hour, 56 amps for 15 min, 112amps for 7min, 224amps for 3.5 min, 450amps for 1.7min, and near 900amps for almost 45 seconds. (all in a perfect situation. actual results will be less)
this is what the amp/hr vs CCA means on the batteries.
oh, to answer the question, yes, no problem using a battery of greater or lessor amp/hour ratings.
Mk
Old 09-02-2012, 08:41 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Either will be fine. Both offer more than adequate cold cranking amps for starting your car. The amp-hour rating indicates, indirectly, how long the battery can maintain cranking demands. For most of us, the difference of 3 amp hours is moot.
Old 09-02-2012, 10:22 PM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
As a practical matter, use the highest Amp/hr rating and cranking Amp rating that will fit in the battery box, and that you want to pay for.
I also greatly prefer to have a warranty that is good anywhere, so I often end up at Walmart...
Old 09-03-2012, 01:57 AM
PHIL928
PHIL928's Avatar
Higher battery ah can mean a slightly bigger battery, I have a BOSCH S4 80ah in my GTS and it's a very very tight fit.
I had to bend the lip in the battery well down on one corner
Old 09-03-2012, 05:06 PM
Leon Speed
Leon Speed's Avatar
Thanks all for the replies. Ordered the Bosch S5. Hope it holds better than the previous two (other brands).
Old 09-03-2012, 08:20 PM
jpitman2
jpitman2's Avatar
Like Wally said, biggest that will fit in the holder. I am running an 88Ah in the 928, cos its whats specced, and fits. The Suby specs a 55Ah, but I can fit a 75Ah in , so thats what its got.
jp 83 Euro S AT 54k
Old 09-04-2012, 08:51 AM
c_span
c_span's Avatar
Just in the interests of recording useful info, would that be part number "0 092 S50 080" / short code "S5 008"?
Old 09-04-2012, 11:52 AM
Leon Speed
Leon Speed's Avatar
Yes that's the one.
Bosch has S6, S5, S4 and S3 battery models for our 928.
From their catalogue:
928 Type, model year, Ah, CCA, short code (4 choices)
4.7 09.82-11.84 95 850 S6 002 85 800 S5 010 74 680 S4 008 70 640 S3 008
S 08.83-07.86 70 760 S6 001 85 800 S5 010 74 680 S4 008 70 640 S3 008
5.0 GT 01.89-07.91 70 760 S6 001 77 780 S5 008 74 680 S4 008 70 640 S3 008
S4, S4/CS 08.86-07.91 70 760 S6 001 77 780 S5 008 74 680 S4 008 70 640 S3 008
5.4 GTS 08.91-11.95 70 760 S6 001 85 800 S5 010 74 680 S4 008 70 640 S3 008
http://aa.bosch.de/aa-batterien/de/p...g_2009_PKW.pdf
Quick Reply: Battery Ah rating
