928 Forum 1978-1995
Sponsored by: 928 Specialists
NEW VIDEO. Rattle at idle still here after new starter.
Old 06-30-2012, 03:39 PM
Dean_Fuller
Dean_Fuller's Avatar
Default NEW VIDEO. Rattle at idle still here after new starter.
PLEASE take a listen and let me know what you think.
The exhaust is tight and not hitting anywhere.
Heat shields are tight.
New starter so that is okay and tight.
Just released tension on the collar and re torqued.
All bolts on the fly wheel are tight.
The rattle is most evident when the car first starts and when its turned off.
I have heard bad torque tube bearings before and to me does not sound like this. In other words its not constant.
I am out of ideas...any feedback would help. Thanks in advance.
Old 06-30-2012, 03:44 PM
Ducman82
Ducman82's Avatar
does it do that whilst on the road?
Old 06-30-2012, 03:47 PM
Dean_Fuller
Yes I can hear the rattle at stop lights and while accelerating from stop. I can not hear it above say 20 MPH....Its like it stabilizes above a certain RPM.
Old 06-30-2012, 03:54 PM
Glen McCartney
Glen McCartney's Avatar
Cracks in the flex plate?
Old 06-30-2012, 03:55 PM
Ducman82
Ducman82's Avatar
funny thing. my car did the same dang noise... never did figure it out. it just stared one day. got so mad i took the engine out. thought it was a valve issue, nope. never did find out what it was........
click the pic for video
Dean_Fuller
I have tried hitting the flex plate with a mallet and I do not get any rattle.
Old 06-30-2012, 03:58 PM
Jadz928
Jadz928's Avatar
I've heard TT failed/failing bearning whine, and also rattle. Kindof a marbly rattle.
Might want to put a.stethoscope on the TT and other places.
Dean_Fuller
That does sound close. Did it just go away or are you still enjoying the rattle?
My rattle is load enough to be embarrassing.
Old 06-30-2012, 04:00 PM
Dean_Fuller
Dear LORD...don't let it be a TT bearing. I will try that. I discounted it because its only at LOW rpm and not constant.
Old 06-30-2012, 04:09 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
The rattle continues just slightly after the flywheel stops rotating, and didn't you say you could get it just by banging on the starter? Can you still do that?
I'm thinking loose heatshield or other loose part on the outside of the motor or its surroudings, like the crossmember. It sounds somewhat tinny, like a thin heatshield. Something loose sitting on the top of the bellhousing and vibrating as the engine vibrates.
Can you locate it more specifically with a piece of listening (heater) hose? If it's a TT bearing, a listening hose inserted in the TT end opening should locate that.
Note the flexplate is TWO sheets of steel, so it is possible for it to have a cracked arm in one sheet which could be hard to see. Feel the backside of the plate. I have seen one that had a broken arm (both sheets) and it only rattled briefly when the car was started or when you turned it off.
Old 06-30-2012, 04:38 PM
Jadz928
Jadz928's Avatar
Didn't mean to scare you...
Originally Posted by Bill Ball
...I'm thinking loose heatshield or other loose part on the outside of the motor or it's surroudings, like the crossmember. It sounds somewhat tinny, like a thin heatshield. Something loose sitting on the top of the bellhousing and vibrating as the engine vibrates.
I went to listen to it on puter with better sound. It is quite tinny.
Does it often do it as you let off throttle?
Old 06-30-2012, 04:58 PM
Ducman82
Ducman82's Avatar
i got mad and tore the engine out. that sucker had more issues anyway (eaten cam gears, leaks)
Old 07-01-2012, 12:09 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
So, Dean, I see in another thread
https://rennlist.com/forums/928-foru...t-rebuild.html
that you have concluded it's the TT bearings. Did the listening hose nail that down?
Old 07-01-2012, 12:58 AM
Dean_Fuller
Some what. I used my stethoscope and the sounds seems to be coming from the TT housing.
Old 07-01-2012, 01:08 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Yeah, hard to nail that down with the exhaust shielding in the way. If it's the front bearing, I would think a "listening hose" would nail it.
Quick Reply: NEW VIDEO. Rattle at idle still here after new starter.
