928 Forum 1978-1995
Sponsored by: 928 Specialists
Rear suspension carrier-damaged camber adjust area
Old 04-17-2012, 11:40 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Originally Posted by ammonman
The cosmetics don't bother me. Just want to make sure I have enough adjustment after new upper arm bushings are installed.
You may not even on the undamaged side. Also, from that pic, it looks like there is still more adjustment left in the positive direction. Definitely change the upper control arm bushings. If you can get it to between -1 and -0.5, be happy.
Old 04-17-2012, 08:31 PM
ammonman
ammonman's Avatar
Thanks Bill. I plan to do the inner bushes on the lower arm as well while I have it all apart. I think I'll chance reusing the one I have as a used carrier looks to be $250 and up. The later version sees a little more rare.
Mike
Old 04-17-2012, 08:47 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
I had that damage..but was a little worse.
WHILE the tranny was out, was no big deal to get a replacement unit fro 928intl.
I could still align with the damage tho.
Old 04-17-2012, 10:34 PM
ammonman
ammonman's Avatar
My alignment is close with my worn out upper arm bushings. Hopefully new bushings top and bottom will allow me to get back into spec.
Quick Reply: Rear suspension carrier-damaged camber adjust area
