928 Forum 1978-1995
Sponsored by: 928 Specialists
NEW High Flow 2-1/2" Cat Back system 87 to 95
Old 01-13-2012, 10:29 AM
  #61
Cosmo Kramer
Cosmo Kramer's Avatar
Originally Posted by SMTCapeCod
I'm not following...the S4 system works fine on S2 ans S3 (speaking of market segment) up until the bumper cover, just need to add a mid mounting point and an 86.5 final muffler or RMB. But downpipe, cats/bypass and mids are all basically compatible.
True though, that the cost to buy the whole thing and then rework that final segment is not a strong inducement.
Overall, custom shops have proliferated and equipment has gotten better, so owners having shops do their own one-offs probably is a good way to go.
I thought the 86.5 and up have different floor pans and battery box to accommodate the exhaust on the passenger side? My exhaust is dual but runs together on the driver side instead of splitting like the newer ones do.
I was considering doing a custom 3" single but I am not sure how that will work performance wise having an X pipe.
Old 01-13-2012, 02:36 PM
  #62
Jon B.
Jon B.'s Avatar
Originally Posted by LEADASS
Mike Frye, I have found no one willing to throw down on an S3 system. Dave Lomas/ Garrity don't see a real return on the current system and the S3 crowd just isn't there. I think we are left with your local shop fabbing something. I've been waiting and calling but by spring I think I'll just go with local. Brian
I'm probably going to go with a fabbed setup also considering I'm going to be buying headers, but I think that the market IS there for an S3 exhaust. Look at all the people using Ken's chips with their S3. I'm sure all of them (including me) would be willing to shell out for a bolt up system from the manifolds back including a nice X crossover.
Old 01-13-2012, 03:15 PM
  #63
SMTCapeCod
SMTCapeCod's Avatar
I think the battery box issue is limited to '78. I could be wrong.
I'm running 86.5 on my 83 Euro, no floorpan/clearance issues....been so long since I've looked though, not sure whether there is adifference left and right. Substantive difference, I mean, I realize the original routing is on driver's side...
I've read a number of posts that indicate great results from single 3"- good power and also solid torque.
I think Motorsports posted results at one point.
Old 01-13-2012, 07:40 PM
  #64
Mike Frye
Craic Head
Mike Frye's Avatar
Yeah, I know. Actually I think Carl and 928MS had a kit a couple of years ago he was working on but it never generated enough interest I guess.
This is true. The 86.5 belly pan is identical to the S4 and already has dual exhaust so this cat-back system should work and actually could be called the '86.5+ High Flow Cat-Back System'. But I guess that just doesn't sing, does it?
Ted, you're right. The problem with the '85 and early '86 is the battery box and the lack of exhaust hangers (which can be added of course).
JHowell37 fabbed up a system of his own by 'modifying' the battery box. I think he said he used the 5 lb sledge.
I guess there just isn't enough of a market for the S3 cat-back high flow setup since it was originally a 2-into-1-into-2 system and it would require something more than just bolting on a new set of pipes.
Can't blame a guy for asking though, right?
Old 01-13-2012, 08:28 PM
  #65
SMTCapeCod
SMTCapeCod's Avatar
Carl's V1 system.
Crush bends sure are weaksauce by comparison.
Installed with 86.5 muffler. No battery box issue.
It's still remarkable that a angled S2/S3 final muffler solution paired to the existing design for mid pipes is too big a mountain to climb.
File Type: pdf
Old 01-13-2012, 11:55 PM
  #66
JHowell37
JHowell37's Avatar
Believe it or not, that is one thing I have not used a sledge hammer on. A few years ago I did have GT resonators on my '85. You don't have to modify the battery box, but it is a tight fit with little clearance. I drilled through my cross member to hang the exhaust. I only used that setup for about 10 months before I switched back to the standard '85 exhaust, X-pipe, and no cats.
A few months ago I swapped out my cross member for one from a S4/GT so I now have the proper mounts. I also got another set of GT resonators. My first set was actually damaged so I off loaded them onto Landseer. I need a few pieces of hardware and I can put it back on. I just haven't been feeling motivated lately.
Old 09-26-2012, 08:33 PM
  #67
pcar928fan
pcar928fan's Avatar
Looks like I found the thread I am looking for...
I am ready to move on a high flow cat set up and an X-pipe...
Is that currently available anywhere and it looks like Roger had talked about a total cost around $750 (cats, X and install kit)... Is that still the case? Looking to put this on my '95 ASAP along with the Constantine RMB... I am hoping it will be the perfect sound and power combination!
Old 09-26-2012, 08:49 PM
  #68
ROG100
Basic Sponsor
ROG100's Avatar
Hi James,
Happy to assist - aluminized X pipe is $485 and SS is $675.
A pair of high flow cats is $360.
Plus a fitting kit and shipping - do not forget your 5% OC discount.
High flow cat back system also available as well as per the thread. IIRC the price of the system went up about $100.
Best,
Roger
Old 09-27-2012, 10:32 AM
  #69
Ninespub
Ninespub's Avatar
Hey ROG... any info on the Supersprint Dual system?
Old 09-27-2012, 11:17 AM
  #70
SeanR
SeanR's Avatar
Installed this stainless set up a few weeks back on a customers car, man I want one of these for my car. It's only money.
Old 09-27-2012, 12:30 PM
  #71
Strat_928
Strat_928's Avatar
I have Roger's 3 inch Aluminized Y-Pipe and SS Cat on my 83 16v. Made a BIG diff on performance. Same company that is doing this. Looks good, sounds good.
Roger - any possibly they can make final tube and muffler portion for what I have? Just need the part from the end of the Cat back. It would have to have a slight reduction from 3 in Cat flange to the 2.5 pipe going to the muffler. I know the Borla is supposed to fit, but not only is it expensive but I do not like the way their muffler sits under the back end on some that I have seen. Does not look very integrated.
Old 09-27-2012, 12:50 PM
  #72
Ketchmi
Ketchmi's Avatar
We actually looked into doing a 3" single cat back for early 16 valve cars but it flowed so well that anything less than a 300hp Euro lost a significant amount of torque. It did make the euro cars sing though!
Also, our 16 valve development hasn't been exactly profitable. We easily sell 40 X-pipes for each "Y" pipe. The dual cat back system has had pretty good sales, 5 this month so far but I have had less than 10 total requests for a single cat back for 16v cars in 8 years. I sold our last prototype to a well known Pinata LeMons car.
Hey Rog, what's a Supersprint Dual system?
Old 09-27-2012, 12:52 PM
  #73
SeanR
SeanR's Avatar
I want to know this also. Never heard of it and you'd think I would if something was in development.
Old 09-27-2012, 01:34 PM
  #74
Strat_928
Strat_928's Avatar
Ketchmi - understandable....then I am glad I could get what I have now! It is very good as it is using 85/86 manifolds on my 83, then the Y and SS cat, then stock rsonator/muffler section. Will keep exploring the alternatives for the last part and keep it at 2.5 inch so it does not flow too freely. Right now it definitely feels better than stock, of course the mainfolds help as much most likely!
Old 09-27-2012, 06:06 PM
  #75
Ninespub
Ninespub's Avatar
It's actually not "IN" development. It's a rear muffler system with exhaust pipes that come out BOTH sides of the 928, not just the driver's side. The system is only the rear muffler, the crossover piece and the two tailpipe extentions that of course, requires modifying the rear bumper cover . It's made in Europe and quite cool, actually. I saw it and inquired about it's availlability a while back to ROG. I just figured he had forgotten about it because of his.......you know, wine issues.
Quick Reply: NEW High Flow 2-1/2" Cat Back system 87 to 95
