4spd Automatic Transmission Leak (BIG) at Torque Converter
For those of you who’ve rebuilt and fixed the 4spd automatic transmissions, this one’s for you. I’m fairly adept at wrenching and fixing things as they should be, but this puzzler has me stumped. And, after removing the transmission and replacing all the front seals, now the problem is worse! I know, sounds like operator error to me too….
Searching the forums I found that Heinrich had essentially the same symptoms: https://rennlist.com/forums/928-foru...r-r-and-r.html which turned out to be the front pump gasket damaged during installation.
I guess this post is part ‘public service announcement’ and part ‘what the heck’… I’m not pretending to be an expert and I’m certainly not the documentarian Dwane is (you rock dude!); but this was quite the challenge and I’m hoping this post will be one-stop-shopping to help others trouble shoot the front end of the AT. It was bewildering for me at first but after taking the time to study what was going on it began to make sense and ultimately the job is very do-able… with practice (which it looks like I’ll get more of). Also, Big UP to everyone here – I wouldn’t have been able to do this without some awesome write-ups (Tony, Dwayne, & others – say where’s Steve Cattaneo these days? – and Mr. Merlin) on this site and the amazing amount of knowledge here. This community alone makes me want to keep this car forever because I know an answer isn’t too far away.
Also, after reading other posts about cars catching on fire with leaky ATF around hot exhaust, I consider this a HAZARDOUS condition – NOT drivable, NOT safe. I’ve started my car when warm only to have a HUGE cloud of smoke pour from underneath as ATF sprays on exhaust shields and parts. I’m a dad, I’m not interested in being charred before my time. And, I’m thinking other folks are running into this issue more as the cars age and running the other way…. So here’s the scoop to help demystify what’s going on – everyone please lend your additional $.02.
The Car: 83s with 117k original miles, I’ve had the car almost 2 years, driven it maybe a total of 500 miles. (Yeah, that IS a problem…) Transmission was leaking from the front grate (torque converter housing) just a little bit (like it was low on fluid and taking air in) when I first got it, did a new trans gasket, filter and fluid change to see if it might help. Torqued those pan bolts (7 ft lbs is barely more than hand tightened) – no difference. Next, thought it might be the front pump gasket/seal and/or the torque converter seal which means pull the transmission so I thought I’d have a go at that.
Initial Symptoms: dripping leak in Park or Neutral from front grate TC cover. Leak slowed when in Drive or Reverse (observed while car was running w/ P-Brake on, flat and level surface). Trans level per spec (and I’m expert at this now…) After removing transmission and replacing seals at front (TC seal, pump housing gasket, main pump seal) the transmission practically POURS ATF when in Neutral and Park and reduces flow by 50% when in gear (Reverse or Drive), still dripping. When I start the car and the TC fills up I lose about 8oz of foamy fluid in about 2 minutes!
Probable Causes (any others you all can think of?):
- Main Pump Gasket wrinkled / torn (Heinrich’s plight in the post above)
- Damaged TC O-ring (nicked or torn) from installing TC again
Scored / damaged / worn TC snout or bushing in main pump (replace both…) I didn’t check these for wear tolerances as I’ve never seen any post or information on checking these – not in the WSM either… Does anyone know of any specs for such stuff?
- Low ATF level (wishful thinking…)
That last one has been curious and accounted for in other posts. Apparently, when low on fluid the transmission will take on air and cause the ATF to foam (teeny tiny bubbles) and then purge this foamy fluid, making it appear as a leak. Same purge process as if the transmission has too much fluid. With hindsight, I’m thinking this could have been my whole problem but I was too inexperienced at checking the ATF level to know better – whether or not this was the case, I was hoping to fix it and replace some old, tired rubber seals and gaskets. Here’s how that went (pictures, with feeling now)…. Remove transmission per WSM (exhaust, rear-sub-frame, etc.) – 2 days later:
Here’s the handy-dandy operating table I rigged up
These are the TC input shaft bearings which I had replaced – I would definitely have a machine shop push out the old and press in the new. My shop had an oven to make the job smoother and not put extra pressure on the housing or risk a crack… You also wind up pushing the flex plate carrier and shaft back in – keep it straight…
Magical Front Pump (as seen from the front):
Here’s a picture of how the pump and housing all sandwich together:
Below is the gasket that seals the interface between the assembly and the housing – this is the gasket that was damaged in Heinrich’s post:
And here’s how they interface (note the pump and the back piece shown in the following pic are not installed on to the pump cover in this picture – yours should have that stuff on there!):
If you’ve searched around about this problem you’ll find that you can’t get to the main pump without removing the piston mounted to the back. I’m not sure what all this is but I’m sure I put it back together the way I found it! There are another (2) seals that go on that shaft as well.
and here's a page from the pet that shows how this all goes together:
Assembly is the reverse of removal… (love that one).
I have to say, after doing all of this work, I’m pleased I could turn the key and didn’t hear some horrible metal mashing sounds, and the car will move under its own power. Unfortunately, there’s a post operation new symptom: driveline shuddering when Reverse is selected (it’s so bad I move the selector to Park or Neutral right away). It starts to shudder when the valve finally opens (or closes?) and the brake band tries (I think) to take hold. The car would back up but I’m afraid I’m gonna do some bigger damage…
Helpful hints for this procedure for those seeking the path:
- I did this job w/ those cheapo-short jack stands and (2) 2-ton $30 hydraulic jacks – it can be done - but next time I’ll go for taller jack stands that extend about 21”. Porken lift bars would be the bomb! And a floor jack that will lift to 21-23” would be perfect. This gets the car off the ground far enough to maneuver most everything including the rear sub-frame out from under the car. I had to lower the front jack stands and tilt the car forward to get mine out from the rear – what a bugger!
- Get all that stuff removed in the engine bay (airbox, MAF, cross brace etc.) as that engine moves a lot. Also, this seems a common time to pinch some of the hoses and tubing mounted to the firewall (brake line, fuel line, etc.) – another potential fire hazard if you’re not careful. I made a practice of lowering the transmission and checked clearance on the firewall just to make sure I didn’t pinch something.
- Undo the tension on the transmission selector cable by removing the selector hardware at the transmission or detaching the cable, if you don’t this will stress the casing as the transmission lowers. New selector cables can be pricey…
And now I’m fully trained (er, I think so…) on transmission fluid level checking. Researching I’ve found several perspectives on this (checking hot, warm, and cold), however, after carefully reading the WSM (check it cold!), and asking other experts, it’s best to do the following:
- Make sure the car is on level ground, parking break on, wheels blocked. You need to be able to put the transmission in PRND and not let it get away from you.
- Check the level COLD. Start engine in Park or Neutral and let the main pump fill up the torque converter, this will take 2 minutes maximum. Check level – it should be at the lowest mark on the reservoir.
- Put the transmission in Reverse for 15 seconds, in Drive for 15 seconds (to allow the valves in the AT to open-close and put the car in gear both directions – this ensures that the fluid is flowing throughout the transmission). Check level – it should be at the lower mark on the reservoir.
- After these 2 checks, add more fluid if necessary to bring the level up to the lower mark. You’re done, the upper marks are for “hot” transmissions which will only happen after you’ve driven the car for 15 minutes and everything is up to temp. I don’t think you’ll have “hot” fluid if you have the car running at idle for 30 minutes while you’re checking levels, engaging transmission, filling with fluid, etc.
- FYI, when the motor turns off and the TC stops spinning, it may drain AT fluid back in to the lower pan and the reservoir will look completely full – see picture.
That’s about it. If you’ve read this far you know what’s ahead for me when I can finally pull up my bootstraps to get it done. My current mantra is: Always faster the 2nd time! I may have to enlist some local supervision to hopefully avoid a 3rd … (perish the thought… something about the smell of ATF…)..
to be continued...
-Paul
to be continued...
-Paul
Good write up, thanks for sharing.
Rennlist Site Sponsor
Did you carefully lubricate the lip and O-ring seals before installation? If you install a lip seal or rotating O-ring seal dry, it will burn in five seconds of operation and be useless...
If I were doing that job, I would get three long bolts with the correct thread, cut the heads off, cut a screwdriver slot and round the ends. Install those to hold the gasket and make it trivial to properly align the pieces during assembly. Install some normal bolts, remove the guide bolts and install the rest of the normal bolts.
Paul,
Sorry to hear about your ATF leak. But I'm REALLY glad you posted! Those are GREAT pictures and annotations!! I was going to work on TT bearings as my next project and was contemplating replacing the transmission seals while I'm in there (although I'm not experiencing any leaks - dry as a bone). Maybe I'll just replace the TC housing bearings. THANKS again for posting - the pictures are very helpful to me! BTW, I like the operating table you've come up with - I may try that!
Wally P - thanks for adding here - I lubricated all the seals with ATF but i'm wondering if there's a better assembly lube for AT's, like vaseline, is there something else to keep them fresh? One consideration in my process is that it took a while (like weeks) to get the transmission to the point where i had the time to get it all back together; that took a few days. So, i'm wondering if any ATF on the seals may have evaporated and left them dry and ineffective.
Is there a better assembly lube? And, i'm also curious - how do you know when to replace the TC / TC Bushing due to wear - does anyone have a spec for diameter of the TC snout or is it purely visual inspection?
The other real question i'm asking about is the reverse problem (shuddering); though it's clear if i'm pumping fluid out all the time, i may not be making enough pressure and that could cause some behavior like that (i'm guessing...).
Dwayne - glad you like the pics! that's a high compliment! i'm just trying to share a bit in the process i'm going through; i bought the car knowing i'd work on it, i don't have the dough to pay someone else to fix it and pray.... but it's a relatively straightforward machine to work on and i just like going down to the garage and looking at it most of the time! (Good thing, cuz it's not getting out much these days...). If your tranny is bone dry i would file that in the "if it ain't broke don't fix it" department. It's my understanding these transmissions are practically bullett-proof in normal use and with regular fluid maintenance. If you're going for the TT, you can easilly do the input shaft bearings and i've heard it noted here more than once that these are often the noise you hear when the "TT goes bad". A very worth it operation and can easily be done without haveing to break any seals that aren't leaking.
Zeus - the original leak was coming from the front of the transmission and leaking out the grate, which if i'm not missing something can only come from (3) places: TC O-ring seal, Main Pump Seal, and the Pump Housing Gasket that Heinrich wrestled with. i'm all ears for other places. The TC drain plug was torqued to spec and didn't show any evidence of leaking.... so those are my assessments.
Thanks to everyone who's read my blathering post up there. any and all constructive / additive comments welcome. Cheers.
-Paul
-Paul
I'd probably use something like Hylomar before I'd use Vaseline. Rx7 guys swear by it. Hylomar is hard to find but the local parts house carries "Non-hardening gasket sealant" by Permatex which is the same thing.
Rest in Peace
Because it does not harden the seals can push out.
Lube the friction part on the inside, install the outside dry.
BTDT and had to do it again.
I am a firm believer in hylomar on gaskets, but not on seals.
YRMV.
Team Owner
Paul , nice writeup, I hope the next time things are fixed
I would suggest to use some silicone grease on the front pump O ring,.
When the trans first starts it will make the foamy fluid till it its close to full , if you wait for 5 mins the fluid should turn back to solid red. similar to how the power steering pump make the fluid foamy when refilled
As has been mentioned before it is better to not touch the large round gasket in the trans housing unless it has been ripped, it should be otherwise be be fine to reuse just wipe off any ATF thats on it ,
If you do remove it you may cause other damage to the sealing surface.
Hi Stan - i'll be going in again this weekend to pull the transmission and hopefully find something amiss. Will do on the silicone grease for the o-ring; i have replacements for all the seals in the front of the transmission so it'll be a do-over for the stuff i posted above. I have the replacement return hose we talked about and will substitute the shorty i had made to replace the factory config. My thinking is it's just leaking way too much to be caused by a crimp in the hose if the rest of the hydraulic channels are separated from the cooler in terms of pressure. So, i'm not going down the diagnostic road of seeing whether the crimp would cause a leak. Hopefully i'll find something i messed up the first time . . . always faster the 2nd time!
