Wipers intermediate mode :-(
Rest in Peace
Okay, here is the skinny!
New motor, new rotor resistor, new delay relay, and the damn thing still does not work! Does the switch in the stalk have any known issues?
Do you get +12V at C6 on the panel, something less than +12V at C7(varying with position of the potentiometer) when you activate interval wipe? Also I think C2 should be seeing +12V but I'm less sure of that. When the WSM diagram shows 7 wires connecting to a mystery box inside a relay that is only identified with a transistor symbol, it's easy to get lost. If those are getting power the switch is probably fine.
Fleet of Foot
Here is my similar wiper issue:
New wiper motor,new relay. Still no intermittent speed and wipers will not shut off once activated. Also the wiper motor mechanism makes a horrendous grinding noise when wiping back and forth.
Thanks Rich
Thanks Rich
Craic Head
Rich,
Got blades?
Just kidding I couldn't resist. You said the 'new' motor makes the noise. Is it really new or used? Can you pull it back out and just put power to it on the bench to see if it makes the noise out of the car?
Got blades?
Rest in Peace
Originally Posted by the flyin' scotsman
Do the wipers work on any position or just non function on intermediate?
Rest in Peace
Originally Posted by NJSharkFan
Rich,
Got blades?
Got blades?
Rest in Peace
Originally Posted by Bill Swift
Is the wiring on the dwell (adjustment) wheel correct/connected? The intermittent function will not work if a wire is wrong or not connected there.
Mike,
yes blades are in place
The wiper motor is used. But the old motor made the same nasty noise too before it finally quit.
The motor is a major league pain to get at. I am not up to taking it out to bench test.
Rich
Rich
Rest in Peace
Originally Posted by SharkSkin
Andre, did you check the terminals I mentioned, or are the frozen peas(incl. the blue ones) keeping you out of the CE panel?
You could come to the house and do it for me
Rest in Peace
Bit of a hike there, Andre. Maybe when you've thawed out, and you're not so grumpy.
