CLUTCH BELL HOUSING JUST WILL NOT GIVE
Old 10-27-2014, 10:55 PM
jackkthemackk
jackkthemackk's Avatar
Default CLUTCH BELL HOUSING JUST WILL NOT GIVE
I've checked every tutorial, read everything, looked at every diagram & I'm stuck. All four bolts are off, both sensors are out, torque tube is out of the way, EVERYTHING. I have the housing as far back as it will go but it just won't come down or completely off.
Any help?
Old 10-27-2014, 11:21 PM
jshep
jshep's Avatar
Default Clutch COver / Bell Housing
Did the motor tilt forward when you removed the torque tube? If so, this may be the issue, as there may be less room to remove it.
Try rotating the front of the engine up slightly (pivot it on the motor mounts). This may help.
Keep the faith!
Old 10-27-2014, 11:24 PM
jackkthemackk
this is the worst engineering I have ever seen dear god who thought it was okay to the transmission this hard to get out & the clutch bell housing this damn hard to get off? It will wiggle around and come out three inches but JUST WONT SLIDE OFF AND DOWN SORRY BUT IM LIVID
Old 10-27-2014, 11:39 PM
Jfrahm
Jfrahm's Avatar
fork removed?
Old 10-27-2014, 11:52 PM
odonnell
odonnell's Avatar
You will definitely need to remove the fork, a mallet or even hammer will be your friend. Don't go full Clarkson though
Old 10-28-2014, 12:01 AM
V2Rocket
Rainman
V2Rocket's Avatar
clearly you've never seen anything designed by the soviets.
Old 10-28-2014, 12:10 AM
lart951
Basic Sponsor
lart951's Avatar
Clutch fork pin needs to come out
Old 10-28-2014, 12:26 PM
jackkthemackk
Originally Posted by Jfrahm
fork removed?
The fork is removed, the clutch housing slides about 4 inches away from the motor but will NOT clear something and come down.. What is stopping it?
Old 10-28-2014, 12:31 PM
lart951
Basic Sponsor
lart951's Avatar
you mean to tell me that you already pulled the clutch pin and also the clutch fork? did you pulled the speed reference sensor bracket?
Old 10-28-2014, 12:46 PM
lart951
Basic Sponsor
lart951's Avatar
this one
Old 10-28-2014, 12:47 PM
jackkthemackk
Yes, and the negative lead ground from the battery. EVERYTHING
Old 10-28-2014, 01:12 PM
V2Rocket
Rainman
V2Rocket's Avatar
is the driveshaft still in the pilot bearing?
Old 10-28-2014, 01:28 PM
wildcat077
wildcat077's Avatar
Yes i remember that being a real pain to remove when i replaced my clutch this summer,do you still have the heat insulation in the tunnel area ... that's what was giving me a hard time,especially the upper left,eventually when you get the right angle the cover will come off !
Cheers
Phil
Old 10-28-2014, 01:58 PM
mytrplseven
mytrplseven's Avatar
It sounds like the BH is up against the upper part of the tunnel. You should be able to move it far enough after you jack the front of the engine up around an inch. Use a block of wood on the jack so you don't damage the oil pan. A rubber or plastic mallet will help convince it to move further as well.
Old 10-28-2014, 02:01 PM
jackkthemackk
does the cross over pipe HAVE to come off for the housing to come down?
Quick Reply: CLUTCH BELL HOUSING JUST WILL NOT GIVE
