968 timing belt tensioner Pivot arm
Old 08-01-2014, 02:45 AM
MB968
MB968's Avatar
When I did my rebuild 2 years ago, I used 263 which is Loctite's recommended replacement for 270. And as was said above, if you compare specs, they are very similar.
Note 263, in spite of its red color is different than what used to be referred to as red loctite which is 271 (as I recall), and is very difficult to remove.
Old 08-01-2014, 01:16 PM
OakRZB
OakRZB's Avatar
Thanks for confirming MB968. The amount of info on this forum is simply amazing...
Quick Reply: 968 timing belt tensioner Pivot arm
