3D Printing for the 944
Old 02-06-2014, 08:34 PM
  #61
konakat
konakat's Avatar
Originally Posted by V2Rocket_aka944
Think you could make a new version of the early 944/924S shifter surround trim ring? The plastic that snaps into the console, that the leather boot wraps around?
Seconded!
Old 02-06-2014, 10:37 PM
  #62
southbayy
2nd Gear
southbayy's Avatar
great idea making parts , what temp will they take ? and can you use filament with better UV resistance ?
Old 02-07-2014, 12:30 AM
  #63
Church
Church's Avatar
I'll take a look at my 944 tomorrow morning and come up with pictures of everything that is small and usually gets broken that you either have to pay a kidney for or can't get anymore. Any idea's I get from it for little "aftermarket" doodad's for modified cars I'll supply as much measurements about as possible with my calipers if you are interested in any of them.
What is the heat/stress tolerance on the plastic you use (I know absolutely nothing about 3d printing other than it uses a small injector needle to layer melted plastic into a 3d shape.) and is there clear options? I know the turbo turn signals are no longer available from porsche.
Old 02-07-2014, 01:03 AM
  #64
odonnell
odonnell's Avatar
Originally Posted by J1NX3D
+1 for the early and late style end caps for the luggage roller blind.
I can make the files in Solidworks if someone has access to a 3D printer and wants them. Any detailed pics of the shifter trim ring would help a lot.
Old 02-07-2014, 03:02 PM
  #65
southbayy
2nd Gear
southbayy's Avatar
sausagehacker, I just sent you a message.....Cheers
Old 02-09-2014, 10:33 PM
  #66
bajabluejay
bajabluejay's Avatar
Hey Guys!
I know I've been MIA for a while...semester starting off strong and applying for jobs is pretty much all-consuming!
@Josh:
I was a bit delayed on the print waiting for the limonene solvent to dissolve the High Impact Polystyrene filament that is used for the support material. It finally came in and I got to see how the actual part turned out. Not so great in the first attempt, but I'm going to change some things on the model and G-Code settings. It was my first part with support material, and in the areas where the ABS goes right up to the HIPS in a given layer, it gets ugly.
Does anyone have a photo of this tab in place? That would help for understanding what features are critical.
@ELLSSUU:
I'm going to boot over to SolidWorks and print you out a 2D drawing to confirm what you need modified for the Sport Seat. Happy to make it once we have the model nailed down!
Luggage Caps:
Now I get it. I can definitely do A and B
Does anyone have a set to send? Wouldn't even need support material. The visible cap end would look like a molded part given that it's printed right on the plate.
Old 02-09-2014, 10:45 PM
  #67
Josh B
Josh B's Avatar
Here are some pics of one of the tabs in application.
Old 02-09-2014, 11:19 PM
  #68
V2Rocket
Rainman
V2Rocket's Avatar
https://rennlist.com/forums/944-turb...-a-budget.html
Old 02-10-2014, 12:00 AM
  #69
kens_74911s
kens_74911s's Avatar
Default Make it better not just "make it"
This process was not intended to make production parts. If you want to duplicate it's way simpler to just make molds of existing components with stronger materials then mass produce them off the molds. There are ways that we can improve parts that fail, simple copy with weak composites is not it.
Rethink , In the model, consider making a change to the original design that will make it more robust, modify materials, add material, enlarge radii etc.
Look at failure modes and areas that need attention. There is some good 3D modeling going on here. It's copying existing work so far on this thread, that's a good start. I challenge these designers to get big and make it better.
K
http://home.roadrunner.com/~autotech2007/
Old 02-10-2014, 08:50 AM
  #70
Josh B
Josh B's Avatar
Thanks Spencer - in this case I'm not trying to "Euroize" foglights - just repair stocks ones. I'm not a big fan of the euro fogs because they never get wired up right
Old 02-27-2014, 10:56 AM
  #71
Josh B
Josh B's Avatar
Bump - any updates?
Old 03-02-2014, 02:36 PM
  #72
holtzy822
holtzy822's Avatar
I second the shifter cap, would be cool to have one with 944 on it
Old 03-02-2014, 07:32 PM
  #73
raleighBahn
raleighBahn's Avatar
I think plastic speaker adapters for both the 10 speaker (i have) and 4 speaker layouts. Something that maps to modern US speaker holes.
Old 04-09-2014, 12:02 PM
  #74
Josh B
Josh B's Avatar
Old 04-09-2014, 12:13 PM
  #75
porsche_dreamer
porsche_dreamer's Avatar
I 2nd the shifter cap!
Quick Reply: 3D Printing for the 944
