3D Printing for the 944
Old 01-23-2014, 12:25 PM
  #46
Butters944
Today I got
My Custom Title
Butters944's Avatar
Location: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
Originally Posted by RoyaleWithCheese
I was looking into doing this a while back for a tail light on a vintage motorcycle I had that cracked and couldn't find the part anymore, and came across this page:
http://www.lowbrowcustoms.com/page-v...il_light_lens/
I'm sure there are much better ways to do it than that and to replicate the lenses you will have to do a 2 part mold which definitely complicates things. For simple projects though that is a cheap DIY way to do it and can be dyed any color or left clear.
The ones I plan on making will be made using high quality silicon two part molds and high quality clear plastic resin, and I will use a pressure chamber to remove any bubbles from the pieces. Hopefully they will be as perfect as the kinds you used to be able to buy from hookedoncars and can still buy at Klears (for too much money).
Old 01-24-2014, 09:45 AM
  #47
V2Rocket
Rainman
V2Rocket's Avatar
could you print say...a modified porsche badge?
Old 01-24-2014, 11:14 AM
  #48
konakat
konakat's Avatar
Originally Posted by theedge
Upgrade to a late car
Upgrade? I'm confused
Old 01-25-2014, 12:09 AM
  #49
Josh B
Josh B's Avatar
Hey BajaBlueJay - I sure would be interested in buying a bunch of these if you could make them. They are the plastic adjustment pieces for the lenses on a Porsche 944 turbo fog light. Always seem to be broken and they don't glue back together that well. I could send you one to model off of....
Old 01-25-2014, 09:43 AM
  #50
curtisr
curtisr's Avatar
Not sure if they would be strong enough but, it seems to me that one cannot have too many air-dam hinges.
Old 01-30-2014, 01:34 AM
  #51
bajabluejay
bajabluejay's Avatar
A little update for you guys,
I've taken up Josh's challenge, and he kindly sent me the clips. I've modeled them up, and have them in the printer as I type. I'll be experimenting with the new disolvable material (high impact polystyrene that dissolves in d-limonene citrus cleaner). For these complicated clips, I want to make sure the entire print is surrounded in support.
Attached is a render of what I came up in SolidWorks.
With the low winter sun getting to me, I finally sourced some sun visors on ebay. Made up the interior clips to print. Note the white lines visible on the mouth of the clip. This is because I printed with break-away supports, not dissolvable. They fit nice and snug though!
Scott and Van, I'll get back to you guys tomorrow!
Old 01-30-2014, 07:17 AM
  #52
Van
Van's Avatar
Looking good!
Old 01-30-2014, 08:05 AM
  #53
Josh B
Josh B's Avatar
Sweet!
Old 01-30-2014, 10:40 AM
  #54
ELLSSUU
Geaux Tigers!
ELLSSUU's Avatar
Originally Posted by Josh B
Sweet!
Yes indeed. Great suggestion Josh. I think that I need one too.
Old 02-01-2014, 04:19 PM
  #55
OakRZB
OakRZB's Avatar
Originally Posted by sausagehacker
...maybe a dashboard?
But seriously
+1 on the dashboard - if only....
Old 02-06-2014, 08:48 AM
  #56
Josh B
Josh B's Avatar
Bump - any updates?
Old 02-06-2014, 12:14 PM
  #57
raleighBahn
raleighBahn's Avatar
How about the plastic piece (I think there are three) that keep the ignition wires together and off the manifold?
Old 02-06-2014, 03:29 PM
  #58
Arominus
Arominus's Avatar
Those are still available from Porsche, I just put them on my S. They live in a high heat area so I don't think the printed ones would live.
Old 02-06-2014, 07:30 PM
  #59
J1NX3D
J1NX3D's Avatar
+1 for the early and late style end caps for the luggage roller blind. I
from 944online
Cargo Cover End Cap
Brand new cargo cover end cap for your 944. Caps A and B have been discontinued by Porsche
Price $17.95
Aluminum Cargo Cover End Cap Set
*** DISCONTINUED ***
Old 02-06-2014, 07:33 PM
  #60
V2Rocket
Rainman
V2Rocket's Avatar
Think you could make a new version of the early 944/924S shifter surround trim ring? The plastic that snaps into the console, that the leather boot wraps around?
Quick Reply: 3D Printing for the 944
