3D Printing for the 944
#31
Awesome to see this thread since I work in 3D printing!
I work doing 3D rapid prototyping and have several types of 3D printers at my disposal as well as a 3D scanner.
I've been planning on printing some custom headlight buckets. I would like to do a couple offset projector headlamps and have the buckets slightly contour to the curves of the lights so they look a bit more modern vs. the square lamp buckets offered elsewhere.
The trick will be to make them clean and functional without them getting ricey looking.
Once they're printed, molds will be taken from the prints so they can be replicated in FG.
There is a gun that can be printed on a home 3D printer that shoots a single .22 round although there is a very good chance you'll get hurt. The printers that print the gun receivers that last longer than 1 shot are produced using plastic sintering printers that cost 100k+ (even those only last around 30 rounds before breaking).
It's feasible to make high strength or high temp parts but financially the technology is still too new to be affordable to the average consumer.
#32
Today I got
My Custom Title
My Custom Title
I believe you can do natural. However because of the nature of 3D printing, the light transfer wouldn't work. You need a smooth substance throughout for the light to travel through it to the desired spot.
I din't know they're NLA. Best bet is to get a plastic company to reverse-mold it, and mold new ones in clear plastic. Might cost a fortune though.
We'll see how it goes come summertime
#33
Loving the response to this post!
Here are a few things I'd like to try immediately:
Switch Blanks for fore-of-shifter switches
Shifter **** Cap
Early/Late Cupholder Solutions
End Caps for Luggage Cover
Would need some dimensions from someone for this one, may rear is all stripped at the moment!
Custom Phone Dock
I use a ProClip mount, but it would be a nice challenge to make a 944 specific smartphone/GPS mount.
Seat Buttons
Not sure if ELLSSUU means the bottom and back slides, vertical adjustments, or what I already printed?
Seat Slide Pull Covers
To complement what I already printed, I need to make the plastic cover that sits between the pull and the seat.
Also, a good article on the whole printed gun distraction: hackaday.com
Shifter **** Cap
Custom Phone Dock
Seat Buttons
#36
At work, we have some Stainless Steel parts being printed by a vendor who sinters powdered metal with a laser. It's expensive, but you can make parts that couldn't be made by conventional machining. 3D printers for plastic are getting pretty cheap these days, especially if you build a kit.
#37
I agree, 2500ish for a plastic 3D printer is a steal in my opinion, I hope to have one in my workshop in a few years when prices come down even more. My goal is to put together a nice capable home machine shop with your basic machine tools like a drill press, mill, lathe, 3d printer, and a plasma cutter. Or maybe I should just spring for an older, used multi axis CNC machine..
#39
I'm planning on learning about/trying my hands at DIY plastic molding over the summer. My goal is, if I get good at it, to make decent quality (probably not perfect but good enough) and very inexpensive 944 parts (cause I love y'all and wanna contribute to the community somehow). Things like clear turn signals, those clear plastic ac control panel things, etc etc.
http://www.lowbrowcustoms.com/page-v...il_light_lens/
I'm sure there are much better ways to do it than that and to replicate the lenses you will have to do a 2 part mold which definitely complicates things. For simple projects though that is a cheap DIY way to do it and can be dyed any color or left clear.
#41
Theres no point to making the switch filler parts. The one that goes where the fader was is $4 and the ones that fill in the switch holes are $3 each. I dont think youre going to be able to compete with that. And the one for the fader hole has quite a curve to the surface that youd have to duplicate.
#42
We have a 3d printer at work, and just today we were all "joking" about printing legos and stuff... I'm happy to see this thread!
How about custom key heads? Specifically, for the guys with the plastic key head with the light (not the round rubber head). You could make anything, from a Porsche emblem shaped head, to a lightsaber hilt, LOL.
968 brake cooling scoops?
924/944.1 2-gauge panel for center of dash?
Those stupid sunroof hinge pieces that always break?
A zip-tie at loooooooong as you want?
I would love to get the file for the glovebox hinges too!
#44
Rainman
