But what is it in relation to 130mm in late model porsches?
huh? Offset is how far from the centerline the wheel mounts. Early cars are ~23.3mm, later Porsches including the late 944 use anything from around 50-70mm from what I've seen. Where are you getting 130mm? Only thing I've seen that involves the wheels and 130mm is the bolt pattern which is 5x130mm.
Most, if not all, Porsche wheels will fit any Porsche (excepting 4-bolt 914/924s and possibly Cayeene?). They use the 5x130 pattern. The offset difference will make the wheels stick out from the fenders.
