924 and 931 Forum 1976-1988
Rod Bearings
Old 10-02-2016, 10:13 AM
RonLex
8th Gear
RonLex's Avatar
Default Rod Bearings
Hey, everybody,
Planning to pull the engine on my 924s to do rod bearings in a couple weeks (as a preventive measure (most likely will be a LeMons car)). Looking for some recommendations on the parts list for the job. I'll be doing the balance shaft delete, as well (don't try to talk me out of it), so I'm planning to use the pick up tube reinforcement from Paragon. Trying to keep this as minimal as possible, my list so far:
-Main seals
-Oil pan gasket
-rod bearings
I appreciate any input on the subject in general!
Old 10-02-2016, 06:18 PM
V2Rocket
Rainman
V2Rocket's Avatar
If you do the BS delete, use medium strength (blue) loctite/threadlocker on EVERYTHING.
Old 10-20-2016, 09:08 PM
mrgreenjeans
mrgreenjeans's Avatar
Location: Marco Island , FL --- Red River Valley, midwest
AND:
keep a sharp eye on your fuel rail, because it will crack and spray fuel everywhere.
If you care, ask me how I know this. ( while riding in a car ON track giving instruction & smelling vapors )
Old 10-21-2016, 05:40 AM
mel_t_vin
mel_t_vin's Avatar
Originally Posted by RonLex
(most likely will be a LeMons car). I'll be doing the balance shaft delete, as well.
Why...to save 3 kg, free up 2 hp, and delete 1 belt?
Old 10-25-2016, 07:10 PM
KevinGross
KevinGross's Avatar
New nuts for the con rod bolts.
Old 10-26-2016, 09:14 PM
V2Rocket
Rainman
V2Rocket's Avatar
and a partridge in a pear tree
Old 11-16-2016, 03:26 AM
Arominus
Arominus's Avatar
Run the shafts, it will make you more reliable. Also you don't need to pull the motor to do the rod bearings. Get an engine support bar (harbor freight $60ish) and drop the crossmember and pan to get to them.
I just did them in my car over a weekend, its really not that bad. I didn't even take the rack off the crossmember or pop the tie rods, i just slid it forward and worked.
Quick Reply: Rod Bearings
